04-06-2022, 12:32 PM | #1 |
Rep 652
Squeaky brakes
Talk about some SQUEAKY brakes... my f10 m5 wasn't this bad. I'm changing out the rear brake pads to akebono, but the only brand offered for the front is Bmw oem pads. I can't tell it the squeak is coming front the front or back brakes, but they're so damn loud even on light press going slow. Anyone else have experience with this? What was your solution, if any?
04-06-2022, 01:32 PM | #2 |
Rep 7,122
Posts Drives: 2018 M2 AW DCT Join Date: Aug 2012
What BMW are you talking about? Would help with responses.
tracer bullet3621.00 |
04-06-2022, 04:02 PM | #4 |
Friends don't let friends ESS
3654
Rep 970
Posts Drives: '11 Lemans Blue 6mt Harrop e90 Join Date: Dec 2020
Garage List 2011 E90 M3 [9.00]
2003 Porsche 911 Turbo [9.75] 2019 BMW X5 xDrive40i [0.00] 2013 Mercedes E550 ... [0.00] |
Might be time for new rotors, if their surface feels anything but mirror smooth it's a good chance they are the source of your brake noise. 7-8 years on original rotors is a pretty good life length. Aftermarket ceramic pads are more likely to whine, and you can also dampen whine with CRC Brake Quiet - which cuts down on the pad vibrating.
04-06-2022, 04:17 PM | #5 |
Rep 2,493
Brake noise is normal for M cars. Here's a video from Porsche explaining why.
Present: 2023 M2 BSM W/Carbon everything, 6 Speed
Past:2020 M2C HS Executive, 6 Speed |
04-21-2022, 12:36 AM | #7 |
Rep 1
Please help. I have a 2022 BMW M8 comp and the squeak is so bad. I even escalated the problem to the main office in New Jersey and they basically told me to kick rocks. I’ve taken to a couple different dealerships for service and they just tell me it’s normal. The main office said they can only Lemon it out if they tried to do maintenance on the vehicle, but they just send me home. I have tons of videos but I do not know how to post here.
04-21-2022, 06:42 AM | #8 |
Rep 2,084
Posts Drives: 2022 X6///M Comp Join Date: Aug 2015
Turn up the volume on your stereo . There is no long term fix. My 2016 and 2019 X6Ms squealed like an old school bus. It was worse than nails on a blackboard. There are a bunch of threads in the F85/F86 forum on the squeaky brakes. Some change out the pads but the noise returns.
I thought I was a good person but the way I react when people drive slowly in the left lane would suggest otherwise
04-21-2022, 06:55 AM | #9 | |
Rep 264
04-23-2022, 09:09 AM | #10 |
Rep 5,135
Posts Drives: 22 Z4 M40i, 21 228i Retired Join Date: Sep 2021
I park near the ocean and in the morning there is a mist in the air. Whenever I first back out of my outdoor parking space my brakes make a sound. As soon as I start driving and apply pressure to the brakes the sound disappears.
04-23-2022, 11:40 AM | #11 |
Rep 10,688
Brakes should not generate unusual sounds under normal circumstances. Focusing on the most common sound: squealing / squeaking.
Eliminating one of the unusual yet common reasons: sometime the brake pad sensor is installed incorrectly. So plastic rubs over metal and that's what one hears. Worth checking first. While braking, the brake pad meets the rotor surface, loses a thin sliver of the brake compound, creating brake dust. That's where conditions which contribute to the eventual brake squeaking symptoms converge: weather (moisture in the air), heat, driving style, rotor condition, brake pads compound (from softer to harsher). The goal however is the same: how to minimize the brake dust binding to the rotor surface. Every driver operates in a different environment. The brakes on my BMW vehicles never squealed. I always used OEM brakes, mainly because I prefer aggressive initial bite of softer OEM brake pads which do produce brake dust - a sign that brakes perform their job well. But smooth BMW OEM rotors may not be suited for every environment. How to minimize the brake dust binding to the rotor surface: - Reduce rotor surface temperature - Use drilled / slotted rotors; slotted rotors help shave the surface of the brake pad and prepare a fresh layer of brake compound for the next braking cycle. Drilled rotors also allow the moisture and brake dust to escape M Performance dimpled rotors are not as effective as drilled / slotted aftermarket rotors. Do not buy these rotors. In summary: get a new set of drilled / slotted rotors, new brake wear sensors, a new set of OEM brake pad (softer compound is more desirable with slots). Then - bed the brakes properly and enjoy hopefully fewer brake noises. |
