04-24-2022, 12:40 PM | #67 |
Rep 471
Got the switch installed and followed the directions here as best possible substituting G32_ECE code 2 where G30/Unknown wasn't available.
The problem I ran into is that although the rears work, the inner turn signal no longer flashes. I also did not have "LIC_VERSION_DATA" available to change whatsoever. Any input? |
540iSUP704.00 Cocooningweb4.50 |
04-25-2022, 09:15 AM | #68 |
Rep 803
Wow! I went out to my car to see if I had the same issue and I do. The thing is, the first time I coded using BimmerCode expert mode, everything worked fine. A few months ago my iDrive was updated and wiped out my coding. I redid the coding and I thought everything was cool until I saw this post and went out to my car and checked. Sure enough, only outside lights were signaling.
I'm going to try and do some digging to see what changed. |
04-25-2022, 11:39 AM | #69 | |
Rep 6,869
Drives: '18 M550i|'21 X5|'03 540i
Garage List 2013 VW Tiguan [0.00]
2015 Infiniti QX60 [0.00] 2021 BMW X5 [0.00] 2003 BMW 540i [10.00] 2018 BMW M550 [10.00] |
That said, I know someone who did their own coding and have both working. They gave me their code and 90% of the entries for the G30 were not in my BDC file. I did think about using the G32 entries, but I just gave up. Didn't want to mess with a good thing (LCI perfect functionality) for rear fogs I will probably never use. The person who sent me the coding for the rear fogs had a 540, I found it strange the G30 was just skipped over for the 12 or so parameters I wanted to tweak.
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| |
540iSUP704.00 |
04-25-2022, 07:22 PM | #70 | |
Rep 471
06-09-2022, 03:23 AM | #72 |
Rep 803
I checked my coding and found some updates. I used Bimmercode Expert mode and noticed that the screens have changed since the last time I coded the rear fogs. Everything is still within BDC_Body2 Module.
I could not find NSL Verbaut LCE_BEL_LIN_VAR: Change to match your existing switch, plus "NSL". For example, mine was "39_BEL_PL_FLC_NSW_NIVI", so I changed it to "40_BEL_PL_FLC_NSW_NSL_NIVI". This keeps the incorrect light switch variant error from showing up in ISTA. LIC_LOG_LAMP_2_OUTPUT_CHANNEL_DATA: Change this to "G30_ECE_Code2" LIC_LOG_LAMP_2_OUTPUT_CHANNEL_INDEX: Changed this to "G30_ECE_Code2" LIC_NIVEAU_OVERRIDE_DATA_0: Change this to "G30_ECE_code2" LIC_NIVEAU_OVERRIDE_INDEX: Change this to "G30_ECE_code2" LIC_VERSION_DATA: Changed this to ( I forgot the exact code but it was the one that contained G30_ECE ) |
06-09-2022, 06:58 AM | #73 | |
Rep 6,869
LIC_LOG_LAMP_2_OUTPUT_CHANNEL_INDEX Current: G30_ECE_code | Factory: G30_US_code LIC_LOG_LAMP_2_OUTPUT_CHANNEL_DATA Current: G30_ECE_code | Factory: G30_US_code LIC_NIVEAU_OVERRIDE_INDEX Current: G30_ECE_code8 | Factory: G30_US_code2 LIC_NIVEAU_OVERRIDE_DATA_0 Current: G30_ECE_code6 | Factory: G30_US_code2 LIC_VERSION_DATA Current: G30_ECE_code | Factory: G30_US_code iF ABOVE DOESNT HELP THEN TRY BELOW AS WELL AS ABOVE. LIC_NIVEAU_OVERRIDE_INDEX Current: G30_ECE_code8 | Factory: G30_US_code2 LIC_NIVEAU_OVERRIDE_DATA_0 Current: G30_ECE_code6 | Factory: G30_US_code2
540iSUP704.00 |
07-23-2022, 09:50 PM | #74 | |
Rep 471
07-23-2022, 10:47 PM | #75 |
Rep 803
09-25-2022, 01:37 PM | #76 |
Rep 66
Drives: BMW G30
09-25-2022, 03:39 PM | #77 | |
Rep 5,409
09-25-2022, 04:01 PM | #78 |
Rep 66
Drives: BMW G30
Yes no problem
09-25-2022, 04:33 PM | #79 |
Rep 5,409
10-03-2022, 05:49 AM | #80 | |
Rep 803
ezaircon4jc4577.00 |
10-23-2022, 12:18 AM | #81 | |
Rep 21
10-28-2022, 05:47 PM | #82 | |
Rep 6
No LIC_VERSION_DATA
10-29-2022, 10:15 PM | #83 |
Rep 471
Never got a chance to get back into it and troubleshoot more unfortunately.
Cocooningweb4.50 |
03-12-2023, 03:07 PM | #84 | |
Rep 10
05-24-2023, 04:39 PM | #85 | |
Rep 322
I'm exporting my 2020 540i to Europe and prepare - as much as possible - the vehicle to pass the road test smoothly upon arrival. Today, I installed a set of pre-LCI Euro tail lights that have the rear fog diodes (LEDs). I also installed a Euro light switch (for a rear fogs only, no front fogs, no lane assistance). Not completely unexpected, I discovered that I do not have the wiring. At least not what's in your picture. You mentioned that a wiring in slot 1 and 6 must be present for the fogs to receive a signal. Suggesting that typically those slots are not in use. However, I noticed that I have slot 1 and 6 in use (and 2 and 5 are empty). See pictures, left and right, respectively. Any idea what is going on? Or is this a matter of coding? I requested Bavarian Performance Group (Winchester, MA) to do the wiring for me but they have no appetite for the work. I'm now looking at Sound In Motion (Watertown, MA). Thanks for your advice. |
05-25-2023, 05:40 AM | #86 | |
Rep 6,869
06-15-2023, 03:43 PM | #87 |
Rep 2
Can you send the BDC wiring diagram where to connect the fog light wire? When I coded according to the instructions, the turn signals on the trunk lid stopped flashing, does anyone know why?
06-16-2023, 07:58 AM | #88 |
Rep 6,869
A please would be nice? They say that in Poland, right?
