04-13-2009, 06:53 PM | #45 |
Commander-In-Chief
2206
Rep 8,949
Drives: 2023 M2 Coupe, 2020 GLE 450
Drain plug
It's a hex wrench--going from memory, I think 5mm.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
04-13-2009, 09:32 PM | #47 |
Commander-In-Chief
2206
Rep 8,949
04-26-2009, 03:31 PM | #48 |
Rep 41
I changed my oil today at 6772 miles. Thanks for the info and pictures - it made the process much easier!
It took about 8.75L to get the oil level to the 3/4 full mark. I'm a compulsive extended drainer |
04-27-2009, 03:47 PM | #49 |
Sleepy Member, wishing I was on the road.
34
Rep 280
Where did you guys get the oil filter kit for $17? My stealer (long beach bmw) quoted me $47 for the filter kit, and $10.06 for each quart of oil.
2003 Ducati '996
2008 M3: Sparking Graphite, Red Fox Standard, 19s, Premium pkg, Tech pkg, Premium Enhanced Sound, HD Radio, Heated Front Seats. |
04-27-2009, 03:58 PM | #50 |
Commander-In-Chief
2206
Rep 8,949
List for the filter was $17.77 last year. I paid $15.99 w/ club discount at my dealer. Sure he's got the right part number (I can look it up tonight)?
04-27-2009, 04:11 PM | #51 |
34
Rep 280
Just called them back to check: 11 42 7 837 997 just like in the OP, and still $42.97 (not $47). They said each dealer assigns their own prices...? This makes no sense, but I'm on the phone with South Bay BMW now.
2003 Ducati '996
04-27-2009, 04:34 PM | #52 |
34
Rep 280
So South Bay BMW was $36 and Crevier BMW is $18 through a Roadfly Web discount.
What a bunch of stealers!
2003 Ducati '996
04-28-2009, 04:45 PM | #53 |
Rep 409
Dealers frequently inflate retail (i.e.: "suggested" retail) on maintennance items. Both of the local Seattle dealers are horrendous in this regard.
Jon Maddux
coupenut.blogspot.com x5nut.blogspot.com 16 X5d | 08 M3 Sedan | 06 M Coupe | 01 M coupe | 99 M coupe |
05-19-2009, 03:09 PM | #54 |
Rep 1,334
Ok, just received my oil change kit from getbmwparts.com. It's 9 bottles of engine oil, 2 small metal washers (obviously for the 2 drain plugs), one large rubber ring (i'm assuming for the oil filter), and one small rubber o-ring roughly 5 mm in diameter. Where does the small o-ring go? I was also surprised that it's only the inner filter element. What do you guys use to remove the oil filter housing? A big mutha f'n socket? Just to be sure, you can do the oil change when the engine's completely cold right (so cal room temperature), because I read in that manual the car has to be above 70° ... not sure if they meant if you're checking oil level only, or also when you do a complete oil change.
05-19-2009, 03:28 PM | #55 |
34
Rep 280
When you clean the filter cap off you will see where it goes. At the very tip is the rubber o ring.
Use a socket to take off the housing, just go buy it, you'll need it to get the torque settings right anyhow. If you don't do your oil change with warm oil, it'll just take longer to get out, (~45 mins) and you may not get it all out. I did mine cold, drained forever, filled up 8.5 bottles and I'm dead center on the oil levels. How much was your oil change kit?
2003 Ducati '996
zstreet86116.00 |
05-19-2009, 03:36 PM | #56 |
34
Rep 280
This is what i got off the website... I couldn't find a "kit" for the e92... linky?
Description Qty MSRP Price Your Price Core Price Total Cost OEM BMW TWS Motorsport 10w60 Synthetic Motor Oil 9 $10.65 $9.75 $0.00 $87.75 Maintenance and lubrication, Engine service, Filters, Oil filter, Oil filter, m series 1 $18.12 $14.50 $0.00 $14.50 Total: $102.25
2003 Ducati '996
andysk58534.00 |
05-19-2009, 03:48 PM | #57 | |
Rep 1,334
http://www.trademotion.com/partlocat...catalogid=4462 |
05-19-2009, 04:55 PM | #58 | |||
Commander-In-Chief
2206
Rep 8,949
Oil change
05-19-2009, 05:22 PM | #59 | ||
Rep 409
I received this question via PM and it is worth answering publicly for all... Hi in that manual what's the difference between m6 and m8? Do the two drain plugs have different torque values? M6 and M8 are the diameters of the 2 drain plugs. Yes, they have different torque values as specified in my original post. The torque value for the 36mm oil filter cap is also shown. My car has the same plugs in both locations. I assume BMW called out 2 torque values because some build dates or engines have one size and some have the other. Check the thread size before you torque to be 100% sure. Look here:
Jon Maddux
coupenut.blogspot.com x5nut.blogspot.com 16 X5d | 08 M3 Sedan | 06 M Coupe | 01 M coupe | 99 M coupe Last edited by JonM; 06-04-2010 at 09:58 AM.. |
05-26-2009, 08:50 PM | #61 |
Rep 5,012
Hey folks, an observation why I think we get wrong oil readings: Manual says oil sensor reads oil level EVERY time ignition (or engine?) is turned on, which means if engine is cold, sensor won't read level until oil heats up above 70ºC, which will happen when engine is running, therefore showing a low reading.
I haven't done it, but plan to do the following, since my car is still reading 1/2 full after 9 full liters (hope I didn't overfill it): with car fully hot, will shut it down inside my garage, wait a few minutes for oil to drain back to the sump, then check level with ignition on and see if it reads higher. If not, will start engine and check again, to determine if oil level is checked with engine on or off. Once we learn how level is checked, we should be able to consistently read level correctly. But yes, why the hell BMW couldn't put a damn dipstick is beyond me. Take care. |
06-07-2009, 04:54 PM | #62 | |
Rep 9,034
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
06-07-2009, 07:04 PM | #63 |
34
Rep 280
Yeah... there's another site that sells cheaper oil. Think it something like www.getbmwparts.com. I'm too lazy to figure it out.
2003 Ducati '996
06-08-2009, 03:50 PM | #64 | |
Rep 842
Pretty sure thats their site. Great place to buy from |
07-23-2009, 07:31 PM | #66 |
Commander-In-Chief
2206
Rep 8,949
SI reset
If you're doing in-between changes you don't reset it.
