06-03-2022, 11:29 AM | #23 |
Rep 296
OK thanks, mine's still not done this, keeping my fingers crossed. However did yours make this noise when the brakes were either hot or cold or it was just random and not temperature related?
Cheers... |
06-03-2022, 01:36 PM | #24 |
Rep 42
It's after a long drive, so it would be temperature related. So a swap in the brake rotors, sounds plausible.
06-03-2022, 06:38 PM | #25 |
Rep 63
Definitely not temperature related. It didn't do it all the time, just on odd occasion. My BMW dealership already had a bulletin about this problem so when I took it in they knew straight away and told me the rear brakes need replacing.
BMW M235i Gran Coupe Storm Bay Black Dakota Leather M235i Plus 19"552M Double-spoke Alloy Wheels Technology pack Comfort pack 2 Panoramic Sunroof Driving Assistant Pack
CoopJet3974.50 |
06-04-2022, 12:21 PM | #26 | ||
Rep 14
I also have the M235i gc and it pretty much done it since new but getting worse. |
Dialogue104.50 |
06-05-2022, 06:35 AM | #27 |
Rep 296
Thanks for the information Simon..
06-06-2022, 03:32 PM | #28 |
Rep 118
Hey I have a 228 I 2022 X Dr. and my car has been doing that since I got it at 5400 miles, not temperature related, every time in the morning but also throughout the day, did the dealer replace the rear brakes for free, and do you have the TSB by chance? Thank you
06-06-2022, 06:05 PM | #29 | |
Rep 63
06-06-2022, 08:53 PM | #30 |
Rep 118
That’s cool, I did not buy the brakes package for my car because I have a 30k mile lease and they may not even need pads or rotors, but if so I can change them for cheap. So did the dealer confirm they were able to re-create the noise, or did you send clips of it happening? I just want to be prepared, thanks
06-09-2022, 04:56 PM | #31 |
Rep 118
Do you have the work order by chance for the brake issue? My car is going into the body shop after a minor accident and I’m gonna have them look at that. I have to remember to revert all my coding back to stock, put my stock intake back in, and plug back in the actuator valve on the exhaust lol
06-15-2022, 07:42 PM | #32 | ||
Rep 29
CoopJet3974.50 |
06-28-2022, 05:51 AM | #33 | |
Rep 162
Mosset0.00 |
11-29-2023, 04:49 PM | #34 |
Rep 1
My 2021 228i does this as well, but I am pretty sure it is a resonance issue coming from the underbody paneling as a result of braking in reverse. I am specifically looking at the panel just behind the rear axle line that is supported by lightweight metal framing, and thus more susceptible to resonance. Just assumptions at this point, but I plan to install some sound dampening material on the topside of those panels to see if that helps. This is why the sound tends to linger moments after you stop braking and why it can temporarily go away when you have your brakes serviced. IMO, it's a design flaw. I will keep you posted as to the results of the dampening experiment.
CoopJet3974.50 mblaucoupe135286.50 |
11-30-2023, 12:42 PM | #35 |
Rep 16
Drives: F44 M235i
I also have the same issue when reversing with full swing to the left. There is also a grinding noise on the brakes after cold start. I notified the dealer they checked the brakes and found the rear brakes down to 4mm in under 16000km/10000mi. Brakes were changed under warranty and they have not told me what the issue is.
I am awaiting a courtesy car from them to check the brakes and also a rattle in the roof. Other than these 2 issues, I am truly enjoying this car, it is so much fun to drive. |
01-25-2024, 06:49 PM | #36 |
Rep 1,291
Any update on this issue? My wife's car made this noise really bad during the recent cold snap recently so then I was thinking it might be temperature related. Also a few months ago I switched the pads to an aftermarket one and still get the mooing noise periodically.
01-28-2024, 08:07 AM | #37 |
Rep 16
Drives: F44 M235i
Still waiting for a courtesy car from dealership.
02-14-2024, 06:06 PM | #38 |
Rep 8
Exactly the same happening on my car when going in reverse on a specific low speed. And the sound progressed to happen when moving forward after rear pads replacement. However it went away after around 1.5k km. When going in reverse - still happening. I guess this is not fixable thing. Or it doesn't need fixing.
02-25-2024, 12:52 AM | #39 |
Rep 16
Drives: F44 M235i
Finally got my car in.
They haven't told me what the problem is however they mentioned that they did a "2 Stage Compound" on the brakes, whatever that means. Happy to say, the mooing went away. However one week later the brakes are now squeeling like an old jalopy. Can't win!! |
03-24-2024, 02:16 AM | #41 |
Rep 23
Eh, they are performance brakes. Any performance brakes when they are cold at low speed are going to sound questionable, ask anyone who owns a car with carbon ceramics. It's a minor 4 second long annoyance when I'm backing into my garage, and that's the extent of it for me.
Shra1ZN12.00 |
04-02-2024, 09:26 AM | #42 |
Rep 1
Hi,
I’ve just come across this thread as I’ve now had this noise for a year. The car is E46 and a 52 plate. No issues until front near side caliper and both front discs and pads changed last April. The noise is driving me mad. It started when reversing with the steering wheel turning ie to reverse park but then also will make the noise if the car is in 1st but rolls back, for example while at traffic lights. The noise stops when the brake is applied. The garage were convinced it was a steering issue - new full system and noise is still there. It only happens when car is warm and definitely a resonance rather than a grinding. It also seems to sound as though it’s at the front rather than the rear. If anyone does find the cause of the problem I would be eternally grateful, it’s driving me to distraction |
