F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > left xenon - AHL/DRL/shutter failed?
Studio RSR
      07-10-2015, 05:29 AM   #1
keltis99
keltis99's Avatar
Belgium
25
Drives: 2014 428i
I drive 428i from 2014 with bi-xenon and adaptive lights (lighting package). After I changed the left xenon plug (the cover fixer was broken) I get the following issues on the LEFT side (right xenon is still fully functioning):
Works:
- Xenon low beam
- Blinker
- Fog + cornering lights
Does not work:
- Xenon high beam
- DLR/AHL (rings) off
- Adaptive headlights (+ dash error)
- No up/down light check-up at start-up
Everything worked ok before the plug swap. I rechecked the wiring (via pictures, numbers), cleaned the connections, re-seated the fuses, even put the old plug back – the symptoms/dash errors are the same.
Current issues? AHL module? stepper motors? short circuit?
The car is US import to Europe hence I do not have a warranty anymore… :-(
Thanks for you help
S
bmw 428i (us->eu)
f30post
