10-26-2022, 08:59 AM | #1 |
Rep 1,590
Turbo_Joe Rebuild Thread
Just realized I have never made a build thread for my M3.
Long time build over the years as I bought my M3 as a pristine one owner car almost 8 years ago. TLDR: This is how the car looks right now. Wide body with 18x11 +5 (final offset) 315/30/18 hoosiers, satin pearl white wrap, almost ready for wheel to wheel racing next season. Video of the car in action after the wide body rebuild, I was .3 sec off the track record here: Stock Car: One owner 2012 M3 with 30k miles purchased in 2015 Building a fun street car and starting autocross: Started HPDE: Added a roll bar and some seats/harnesses, upgraded to KW Club Sport suspension, made small changes here and there , added stoptech BBK Started Time Trials 2021: As I got more into HPDE and advanced through the groups I started getting into time trials with NASA. The car was no longer really used on the street and I got a lot more serious with the build. This progressed and I went with larger aero, hoosier slicks, and fully gutted the car and removed the wrap. Prepping for wheel to wheel racing next season (2022): Next step was full 8 point cage and prep the car for wheel to wheel racing. Also installed lexan windows, pulled the radio, and all around tried to lighten the car while adding the cage. Road Atlanta Incident: Running time trials at Road Atlanta I lost the car in turn 3/4 and put it into the tire wall. Lots of cosmetic damage but I knew the car was repairable. I managed to take home first place even though I wrecked in my second session. Wide body to fix wrecked car: After dealing with insurance and finally getting a check for the damages it was time to DIY some repairs. I ended up deciding to go WIDE to easily fit 18x11s with 315s all around on the car. The wide body kit is made by Big Duck Club. Its made for a base 3 series so it took some finesse to make it work on the M3 chassis. Very happy with the end results and the car feels amazing on such wide tires. First track day back after the rebuild I took home P1 in the Car and Driver Lightning Lap Challenge and took home P1 both days of time trials. It was a hell of a redemption weekend for me. Current Build Sheet: 2012 BMW M3 Mod List Exterior: Big Duck Club wide body kit Nine Lives Racing CFD V2 Wing Endplates Nine Lives Racing Swan Neck Wing Race Louver Fender Vents Trackspec Hood Vents Professional Awesome Splitter Rods FAST 3" Naca Duct Plastics4Performance Lexan Windows Aerocatch Hood Latches Laminx Headlight Film (blue) BimmerWorld Carbon Sunroof Delete Interior: OMP HTE-R Race Seat Sparco Martini FIA 6 Point Harness Piper Motorsports Custom Roll Cage Longacre Wide Angle Mirror KMP Steering Wheel with quick release system VAC Motorsports Seat Mount Piper Motorsports Custom Floor Pans Antigravity Li Ion Battery AccuSwitch Switch Panel Suspension/Brakes/Wheels: Apex 18x11+25 VS5-RS Wheels Apex 20mm spacers Stoptech ST60 Front Brakes Stoptech ST40 Rear Brakes SPL Front Lower Control Arms SPL Front Tension Rods SPL Front Swaybar Endlinks M Version SPL Tie Rod Ends KW Clubsport Coilovers Hyperco Springs 750/1000 ECS Tuning Front Sway Bar Turner Motorsport Solid Race Diff Mounts Turner Motorsport Solid Race Subframe Mounts Powerflex Rear Upper Shock Mounts Powerflex Sway Bar Bushings Engine/Trans: BimmerWorld Engine Mounts BimmerWorld Race Exhaust System Eventuri Intake Lid Eventuri Intake Elbow BE Rod Bearings DO88 Oil Cooler Slon Workshop DCT Pan ESS Tuning Software
2012 E92 M3
Instagram Turbo__Joe Last edited by turbo_joe; 08-09-2023 at 09:28 AM.. |
11
Frostynorth432.50 DRLane3996.00 Hein Jockins94.50 roastbeef11593.00 reidetailing636.00 atopa2002204.00 derbo3612.50 SonnyJack326.00 JobanM73.50 redpriest2147.00 DrFerry6734.50 |
10-26-2022, 09:01 AM | #2 |
Rep 1,590
Saved for future updates
2012 E92 M3
Instagram Turbo__Joe |
10-26-2022, 02:06 PM | #4 |
Rep 1,590
2012 E92 M3
DrFerry6734.50 |
10-26-2022, 05:53 PM | #6 |
Rep 2,806
Drives: '09 E90 M3 - IB
315 square. Yup, that outta get the job done.
Glad to see that V2 of the car is faster and more better! I was finally out pushing my repaired beast around Chuckwalla this weekend. Really enjoyed being back in the driver's seat going for lap times.
10-27-2022, 06:42 AM | #8 |
Rep 1,590
Fixed, mixed up links trying to type of such a massive post
2012 E92 M3
DrFerry6734.50 |
10-27-2022, 06:43 AM | #9 |
Rep 1,590
It was a night and day difference having the 315s. The car felt incredible. Going to Summit Point in two weeks and going after the TT3 track record or at least try to get close.
2012 E92 M3
10-28-2022, 06:20 AM | #11 | |
Rep 1,590
All else the same, going from 295s to 315s I shaved 2.2 seconds off my PB at VIR.
2012 E92 M3
10-28-2022, 08:19 AM | #12 |
Rep 1,590
2012 E92 M3
Davisca4552207.50 reidetailing636.00 |
10-29-2022, 07:31 AM | #13 | ||
Rep 2,871
Should be good for another 2sec ? Car looks awesome. Very purposeful |
11-08-2022, 05:45 AM | #14 |
Rep 872
So this is what I missed in October??!! Damn Joey!! Absolutely flying! I will see you this weekend @ SP. A shame we couldn't have had the 75 degree weather from this past weekend. Gonna need your Arctic expedition gear instead!
AA Gen 2 Lvl 2 w/Meth; MagnaFlow catless x-pipe; Dinan Underdrive Pulley; VAC Coated Bearings; ARP Rod Bolts; Oil Diverter Valve; Dinan Strut Braces; Dinan Rear Toe Links; ECS Rear Trailing Arms; MCS 2-Way NR w/700F-1000R; GC Camber Plates; AKG 75D MM & 95A TM; CAE Shifter; Titan T-S5; StopTech ST60 380mm/ST40 355mm; MFactory DS; Zebulon Splitter; Zebulon 330 Rear Wing; Gutted w/Piper Motorsports Custom Cage; OMP WRC-R Seats
11-08-2022, 10:02 AM | #15 | |
Rep 1,590
As long as I can get some heat into the tires my goal is to run sub 1.18
2012 E92 M3
SonnyJack326.00 |
02-17-2023, 07:45 AM | #16 |
Rep 1,590
Some recent updates
Added some front splitter diffusers from Professional Awesome and built a rear diffuser. First time doing anything like this and it ended up being a lot of work. Had to make a lot of custom mounts but very happy with how it turned out. Also started installing my fire suppression, new water bottle for my drink system, digital rear view mirror and redid my switch panel
2012 E92 M3
03-21-2023, 06:38 AM | #17 |
Rep 1,590
Attended competition licesne school with NASA on friday and had my first races. Practice/comp eval race friday (which I won) and three legit races over the weekend. The comp license school was in the rain all day which made things more interesting.
Sundays late race was the best for me, had a rough start getting pushed off in T1 thanks to the guys next to me getting bumped by another car. Came back on track in 11th (from 5th) and fought my way back to finish P4.
2012 E92 M3
03-21-2023, 06:48 PM | #18 | |
Rep 872
turbo_joe1618.50 |
03-22-2023, 11:29 AM | #19 |
Rep 1,590
I saw you in the paddock but was swamped all weekend. I saw you running TT2 i think?
2012 E92 M3
SonnyJack326.00 |
03-22-2023, 12:04 PM | #20 |
Rep 2,527
Drives: 2011 M3/Porsche 992 GT3RS
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
How did you accomplish the widebody? Did you use off-the-shelf parts/kit or did you have to manufacture it yourself?
'06 BMW M3 ZCP 6MT | JRZ RS Pro + Hyperco 650/750 | Epic Tune | Brembo 355mm BBK | too many to list
'11 BMW M3 ZCP DCT | Akra Evolution | Eventuri intake | MCS 3-way | 4.6L Carbahn S65 | Zebulon Aero | AP Racing Radi-CAL BBK by Essex | 305/645-18 Pirelli DHB Porsche 992 GT3, 991.2 GT3RS, 718 Spyder instagram.com/titomanlio |
03-22-2023, 12:59 PM | #21 | |
Rep 1,590
The kit is good enough for a race car
2012 E92 M3
redpriest2147.00 |
03-22-2023, 06:02 PM | #22 | |
Rep 872
During one run this weekend I miscalculated my fuel and basically came in on fumes. The CBS said I had 2 miles until empty so that put me at about a 1/2 gallon of remaining gas. At that level I still weighed 3,610 so basically will be next to impossible for me to get DQ'd for being too light. I was puckered up real good on that cool down lap.
turbo_joe1618.50 |
