10-19-2010, 08:55 AM | #1 |
Rep 813
impressions 2008 IS350 - returning lease
so finally 2 months left on the 36 month lease for a 2008 IS350 i got for the wife .
This will be the first and last lexus. I absolutely hate this car and here's why. 1.Rear view mirror fell off this summer while parked 2.Rain sensing wipers go off completely random (not a drop of rain) 3.Seats adjusters can only perform 1 function at a time when used manually. ( pull seat back and lean has to be 2 separate functions unless using memory - no memory on passenger seat so problem. 4.Vents blow out air of the last temp, even if its turned off. for example if i had the temp @ 60 last, ac/fan is off it'll still blow cold air. same w/ the heat. annoying during cold summer nights followed by hot mornings. (wishing for bmw's cold/hot knob here) 5.Side view mirrors are like dumbo ears ( yes they fixed it in later years) 6.Car down shifts really abruptly when slowing down on a hill. 7.Brakes lasted about 25k - common not even real high performance 8.More brake dust than my m3 - yes they also changed this eventually 9. Not enough info in the center info - again spoiled by bmw 10. bluetooth sound quality sucks - tried several phones 11. Plastic engine cover never seems to close shut and always rattles against the hood when car is starting. 12. Rubber matt recall was a joke - i had the deep groove rubber matts and they simply replaced it w/ cheap flat rubber for the fronts only. now i have non matching front/rear rubber matts. 13. oh and airbag light just went off this morning... at the end none are really deal breakers for most but a bunch of annoying things. My other daily drivers are a RSX-S , E38 740il Sport, E92 m3. Wifey is waiting for the X3 w/ the M sports package.
Huracán Performante 18- Novitec Springs | RR SVR 19 | G05 X5 M50i | E70 11 X5M retired |
Jerez Black E92 10 m3 RE SSK | AFE Filter | Fabspeed XFC / Xpipe | AA ECU 1.5v | BMW PSW | Envy Charger | Megan Exhaust Last edited by novablackm3; 10-19-2010 at 09:18 AM.. |
10-19-2010, 09:27 AM | #2 |
D to the X to the B!
348
Rep 2,106
Can you also add ''lack of interior space'' to your list?? I know it's a sports sedan but camonnnnn, you have no space for a person whose close to 6 feet tall to sit at the back?? Correct me if I'm wrong but 3 series, a4, g35 all have better interior space then lexus IS. IS just looks so cramped that it should be specified as a coupe rather then 4 door.
I'm glad you have gotten rid of the car.
11 corvette C6
10-19-2010, 10:54 AM | #3 | |
Rep 4,013
10-19-2010, 02:04 PM | #4 |
Rep 805
Posts Drives: 2011 Z4 35is Melbourne Red Join Date: Jun 2010
We bailed on our 3 year lease at 2 years for those same reasons and more. That car has no soul. Zero driver feedback was my biggest bitch. Lexus service is not all that either. Our Nav took a dump and it took them 4 weeks to get a disc to repair the software issue. Lots of road noise too. Our Z4 on run flats is quieter than the IS was.
10-19-2010, 03:36 PM | #6 | |
Rep 6,968
3) Doesn't bug me that much since I never had the need to go forward, up and recline at the same time. Once it's set it's done deal 4) Did you hit the off button and select circulate mode? If not it's still pushing outside air through the HVAC at ambient temperature. So on hot days hot air gets in and similarly for cold days. My only complain is the AC is a little too strong and auto temperature is not accurate. So 75 may be fine on certain days but other days it's too cold. 5) They finally fixed in in 2010 6) You probably have it in PWR-ECT mode and the car thinks you are braking hard into a corner so it downshifts aggressively for you to exit the turn. The automatic on this car in 2008 is the weakest point. Basically everything you hate about automatic. 8) yup 9) more annoyed by system locks you out when car is moving. 11) never had this issue 13) or this The key selling point is the car is a looker and reliable. Probably the best designed 4 door sedan for awhile. The weakest point is drivability. Car is a pig at 3700lbs and the suspension is soft to discourage you from spirited driving. I picked one up last Thanksgiving and I am already looking at other cars. It's a good car but not for me. Oh forgot one, it's more tail happy than BMWs.
- There's nothing in my pocket other than knives and lint
10-19-2010, 03:48 PM | #7 |
Scared money don't make money.
68
Rep 1,448
Posts Drives: 2009 E92 M3 DCT Join Date: Apr 2009
+1 for never owning another IS. My wife had hers for 48k miles and here are the issues we encountered:
1) Two full sets of brakes replaced (average life 20k) 2) TPMS malfunction that the dealer could never fix 3) Poor engine performnce and rough idle toward the end (carbon build up?) 4) The ABSOLUTE worst service from Newport Lexus that I have ever encountered
2009 E92 M3/DCT/Alpine White/Fox Red/Carbon Leather OE Tuned 402 whp & 303 wtq/Gintani X-pipe/MXP Axle Back/Rogue Pulley/AFE Stage 2/Cosmetics By IND & EAS HUGE THANKS: Gintani, OE Tuning, and EAS |
10-19-2010, 03:55 PM | #8 |
Rep 6,968
You have to speak more on this. We bought 2 of our ISs there.
10-19-2010, 05:50 PM | #9 | ||
348
Rep 2,106
Anyway, about the carbon build up....are you serious? I get that same rough idle start in the LX570 I own. And I fear you might be on to something as this is one of the few models in this part the region, that has direct injection tech. The petrol grade in dubai really sucks so I got to be careful.
11 corvette C6
10-19-2010, 11:27 PM | #10 | |
Rep 812
Posts Drives: 2009 Hyundai Genesis 3.8 Sedan Join Date: Dec 2007
1. This has never happened to us and ours is an 06. 2. Th rain-sensing wipers work great in our car (though cold air moisture confuses it sometimes. 3. Never noticed this problem and ours has memory on the driver and passenger sides. 4. Never noticed this as a problem. 5. Yes, the mirrors are big but not obtrusively so. 6. Never noticed this. There is no rev-match option though for downshifts like in my G37. 7. Brakes do appear to be a weak point. 8. Got the TSB performed and haven't had any more dust issues. 9. Seems like plenty of info to me, but this sat/nav system dates back to 2006. 10. Phone quality could be better. 11. No issues here for us (though our cover did crack). 12. No rubber mats for us. They did perform the footwell/pedal recall and it was done well. 13. Never had any warning lights but have had a series of TSB's performed under warranty (and Lexus service is beyond reproach). Like you said, there are some nits to pick with this car (like any other) but overall we are very satisfied with our IS350....
2013 Lexus GS 350 F-Sport Starfire Pearl/Flaxen w/nav
2009 Hyundai Genesis 3.8 sedan Sapphire/Tan w/nav 1997 Ford Expedition Eddie Bauer |
10-20-2010, 09:37 AM | #12 | |
Rep 2,312
-annoying Japanese quality - no mechanical issues, major ones (though its only 3 yrs) -no HPFP failure. |
10-21-2010, 08:36 AM | #13 |
Rep 805
Just saw on the news today that IS250 & IS350's are being recalled do to brake issues. Those of you that still have an IS may want to look into it.
10-22-2010, 04:05 AM | #14 | |
Rep 1,756
Funny I just went to the dealer to test drive one to replace my current DD. Thinking about pulling the trigger. CPO car cant go wrong.
Originally Posted by corneredbeast
An engine from a Z06 Corvette. A differential from a Vespa. Damn Quote:
10-26-2010, 11:01 AM | #15 |
Rep 1,644
As a driver most of the time, I've had the displeasure of sitting in my friend's IS350. I swear to God, it was one of the most back-breaking vehicles I've ever rode in as a passenger.
The Good - Engine Usability / Exterior Styling / Interior Quality The Bad - Suspension was hard as SHIT with sports package. The Neutral - Handling was neither stellar nor bad... Just right for the average Lexus demographic.
Former car
2011 BMW 335i Step - Montego Blue / Chestnut Brown |
10-27-2010, 10:38 AM | #17 | |
Rep 245
I traded my 07 IS350 luxury package for my 08 M3.
All I can say is moving from lexus to bmw is a downgrade from "luxury" and an upgrade from "performance" 1. Never had a problem, I prefer the IS350 mirror to the M3 2. I couldnt figure out the computer logic, it was hit and miss 3. Seat adjusters are more friendly on the is350 than on the m3 4. I miss this 5. M3 mirrors are tiny and require me to double check before merging, never had that problem on the is350 haha. 6. Had to be a mechanical issue, didnt have this problem. 7. Brakes were much cheaper to DIY. Lexus gouged if you had them do it. 8. YES! 9. I preferred the Lexus Navi vs BMW Navi 10. Mark Levenson... eats bmw premium sound system for lunch. Rest I won't comment on. Needless to say this will be the last BMW I ever own, however I'd buy a another Lexus in a heartbeat. Had the trigger pulled on an 08 The warranty + customer service here in Edmonton is real showmanship versus the troubles I've had with BMW. Quote:
11-02-2010, 10:41 AM | #18 |
Rep 10,411
Biggest problem with the car is that you cant use the Navi without the car being parked. I do NOT know how people can live with this. I would say the problems you have are minor IMO and the real issue is that it drivers horribly and hard with 0 sportiness. IMO the previous IS drove/Handled better. I am also tired of the interior thing. The interior on thr IS is SOOOO cheap looking and old. The center console is awfull looking. Also how about some real wood Lexus since you are a LUXURY car brand. The quality of the interior is down against a 3 series as well. You can tell this is a toyota interior the second you open the door. The seats are perfect if your over 60 and like sitting on a flat surface. The sport seats in the BMW are light years ahead of the IS. The is does have ventilated seats which a 3 series does not so I guess its better in some ways. Overall IS is nice but lacking in all of the areas I find important when owning a car.
2010 AW e90 328i: 6 speed, Black Leather, Dark Wood trim, ZPP, ZCW, ZVP,ZSP, Nav, Xenon
BMW Performance CF Rear spolier and Gloss black grills 2008 Candy White MKV GTI 2.0T 6 Speed Manul Gone 2008 AW X3 3.0si: 6 speed Returned 2006 AW e90 330i: 6 speed Dinan Stage 1 Returned |
11-02-2010, 11:31 AM | #19 |
Rep 7,594
Posts Drives: '19 M2C Join Date: Jun 2007
My wife's is250awd is going back to the dealer (Lease End in a week)...
What a POS. I have had almost everyone of those issues and some. I also had all the paint peel off from her wheels. Had those replaced. Never going to buy another Lexus.
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
11-02-2010, 11:47 PM | #20 |
Rep 98
I had an 06 IS350 which i traded for the jeep. I liked the 335 back then but since it was 2007 at the time only 335s out were new and i got a used IS with all options for $33k.
I never had any problems with car in 30k miles. The local lexus dealer is still the nicest, best, friendliest dealership i have ever been in. My biggest problem with the car was there was NO soul. By this i mean there was nothing special about the car. It was a luxury car and thats it. I need to have something special about my car. Also every one i saw always had a chick driving, i couldnt get over that. Lastly there were NO performance mods. Intakes and catbacks but neither did anything but noise. Lastly, even in manual mode, if you floored it it would downshift (REALLY annoying). I did like the feel and look of the interior but it was very (japanesey). The one think i absolutely LOVED and wish every car had was the cooled seats. Even in 105 texas heat i never got sweaty on the leather. If only my vette and bimmer had this.
2010 BSM/Saddle E90 335i (M Sport +more)
2006 Vette Z06 (Shifter, Thats it and thats all man) 2001 Honda CBR600F4i Past Cars: 03 Stg 2 WRX, 05 Stg 2 92x, 06 IS350, 86 Vette, 05 Vette, 07 Jeep SRT8, 10 Camaro SS |
11-03-2010, 12:08 AM | #21 | |||||
Rep 1,109
We bought both of ours there but wouldn't spend a dime here in Calgary. Ironically, the Calgary BMW that we've been dealing with has been the BEST dealership of any that we've ever dealt with....to this point. Quote:
Who's driving all the 328's? Performance upgrades are defintiley an area where Lexus is lacking. |
11-03-2010, 09:37 AM | #22 |
The power of V!
99
Rep 1,971
Posts Drives: 2007 335i coupe steptronic Join Date: Aug 2007
Garage List 1998 Lexus Gs400 [0.00]
2010 ebony & ivory [0.00] 2006 BMW X3 [0.00] 2009 pics [0.00] 2009 e92 335 xdrive [0.00] |
Lexus has some new commercials on the tubes featuring the IS line.. There is one in particular depicting a blue IS drifting around the 3 series, C class, A4. Hell, it is echoed that the Lexus IS has more HP & torque than a 335i..
Screw the dyno numbers.. Keep the IS350.. It is a kick ass car that would out run & out handle all in its class!
2007 335 coupe Alpine white, steptronic, sportpack, etc. (gone)
2006 X3 3.0 steptronic Titanium Silver, 2009 E92 335xdrive, next.... Caddy CTS_V! 13 Lincoln MKZ? hmmm. |
