Go Back   BMW E39 5-Series Forum | 5Post.com > BMW 5-Series (E39) Forums (1995 - 2003) > General E39 Discussions
      11-27-2016, 04:18 PM   #1
Sterling Roadster
Drives: e85 Z4 3.0i & e92 328i
The Truth About DISA Valves
As I begin my journey shopping for another early 2000s BMW I was debating getting an e39 with the M52 just so I don't have to worry about the DISA exploding and causing a nuclear holocaust or whatever it's been know to do. The purpose of this thread is to see how many owner's actually know of the DISA causing detrimental cases to the M54 engines, be it yours or someone else's. Now, no doubt it's worth checking out and replacing, but has it really blown motors as much as the internet would have us believe? i'm noticing a lot of companies are making DISAs and preaching to replace it, including ECS Tuning which I respect very much. Please share your stories! Thanks.
      01-06-2017, 03:13 AM   #2
mpathic
Drives: Z4 MCoupe,3.0Si R,E61 535xiT
Consider the DISA a 100k miles service item. Avoid the Chinese knockoff cheap DISA ECS sells. Bought one and it was cheaply made low quality. Stick with BMW brand or OE. There's also the Australian guy on EBay who sells a nice DISA upgrade kit with metal replacements for the brittle plastic parts.
You can also place a bead of silicon rubber on the DISA's seal to the intake manifold to prevent slight vacuum leaks that will drive you nuts looking for after seemingly random "Fuel Shutoff A" and/or "Speed Sensor A" CE.
It only will blow a motor if you ignore the sometimes rough running and CE codes that are telling you something needs to be checked out. The pin and flapper will only go gonzo and down an intake port after more than sufficient warning.
When a DISA is getting cranky, you will most likely see one engine bank running abnormally leaner than the other intermittently depending on engine temperature.
And you may ask yourself, "Where is that large automobile?"
      01-27-2017, 05:59 AM   #3
Obioban
Emperor
Obioban's Avatar
1614
Drives: M3, M3, M5, M5
2008 BMW M5  [0.00]
2017 BMW i3  [0.00]
2005 BMW M3 Coupe  [0.00]
2001 BMW M5  [0.00]
Replacing with OE is just resetting the clock. Do the repair with the GAS kit for far cheaper ($75) and be done with it forever.
https://www.germanautosolutions.com/...repair_kit.php
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport
