Go Back   BMW E39 5-Series Forum | 5Post.com > BMW 5-Series (E39) Forums (1995 - 2003) > General E39 Discussions
      01-19-2018, 07:31 PM   #1
TAmes
Drives: 2021 M5C
Question re: 1998 528i suspension
Hi all,
Two questions for you:
1) My '98 528i has about 120K miles, and I'd like to replace its shocks and springs. I'd like to install the shocks and springs from the sport model. Can someone help me with the part numbers for these shocks and springs?
2) I've noticed that during hard braking (at 60 MPH+), the steering wheel shudders noticeably. I'd appreciate any thoughts on what could be causing this, so I can provide some direction to the service shop.
Thanks!
TA
      02-07-2018, 09:43 AM   #2
W.S.
Drives: 97 528i/5, 2x 07/08 328xiT
Okay, I'll jump in here (this particular subforum seems quiet.
1. Check out Real OEM. You will just need part numbers for "Sport Suspension" instead of "Standard Suspension". If you use your serial you should be able to see these since Sport Pack became optional in MY98.
2. Do you DIY? I ask since it should like you need some front end bushings. There are a few that go bad but the control arms are among the most common. If you have a good Indy shop they should be able to diagnose if you cannot. Most likely it is not warped rotors unless you have cheap aftermarket rotors on the car. Mileage wise, you would be about due for some bushings.
Wade
      02-17-2018, 08:45 PM   #3
chris_flies
Sideways and Smiling
chris_flies's Avatar
3027
Drives: In Exuberance
About your brake-ish juddering, it could be (I don't know the suspension tuning on your cars), as W.S. said the control arm bushings up front, but they usually are also felt just cruising. It could also be a loose caliper mounting bolt/pin that's allowing too much motion, or possibly some pad material stuck on the rotors.
2012 BMW 328i 6-Speed Wagon | Deep Sea Blue with Grey Dakota Leather | Manual Swap, 330i Intake + Tune, 3.15 Helical LSD, Öhlins R&T
(SOLD) 2009 BMW 128i 6-Speed Coupé | Monaco Blue with Black Sensatec | chris_flies' 128i thread
      04-11-2018, 11:41 AM   #4
mabrooks12
Drives: 2011 E90 335xi
Just sent you a PM on the Suspension...
