Go Back   BMW E39 5-Series Forum | 5Post.com > BMW 5-Series (E39) Forums (1995 - 2003) > General E39 Discussions
      09-23-2016, 11:42 AM   #1
ericbikes
Drives: 2000 528i
Brake job for 2000 528i - Did I get scammed?
I took my daughters 2000 528i to local shop to find out why one fr brake was squeaking when stopping. $675 dollars later the shop removed all 4 rotors and "deglazed" them. He told me he took them off and sanded with palm sander. He also replaced all 4 pads even though I know they had less than 20k miles. For this much money, I would have just replaced all the rotors and pads myself for less. To make it worse, please see an image of the rear pads he put on and charged me $95/axle for. They look old and used to me. Looks like he sanded them down and on the outside pad, he sanded them on the long edge. I took these photos about 2 weeks and 100 miles after he said he installed "new" pads. What do you think?? [Oh, btw, they still squeak]
I posted both images on my smugmug site:
https://ericcohen.smugmug.com/BMW-pads/
      09-23-2016, 11:50 AM   #2
Ric in RVA
Bergspyder
Ric in RVA's Avatar
Drives: '11 BMW 128i Sport 6mt
Yup....
Ric in RVA
2011 128i 6 MT Sport, 2009 Cayman 987.2, 2011 528i N52, 2018 F150 Platinum
      09-23-2016, 12:00 PM   #3
ericbikes
Drives: 2000 528i
Thanks for the empathy I told mechanic I would not pay for this part of the work. Do you agree there is NO way these are new pads with 100 miles on them? No idea why he sanded them down. I assume I should now replace these with proper new pads. I'll do the work myself from here out...
      09-23-2016, 12:14 PM   #4
overcoil
Drives: M235i 6spd
Yeah those rear pads look like old pads.
      09-23-2016, 01:01 PM   #5
Ric in RVA
Bergspyder
Ric in RVA's Avatar
You could measure the thickness versus the new ones and I bet they are half the thickness. BMW pads are pretty meaty when new.
No reason to ever sand pads backing plates unless you wanted to fool someone into thinking they were new.
I personally have milled the faces of pads to cut a new surface on them to bed to rotors and remove glaze but no shop would do that...They would just install new.
I don't think hand sanding a rotor to break the glaze is correct either. I'd replace them unless you have sufficient thickness and a good machine shop turn them. (personally I think turning rotors is false economy.)
Next time the start squeaking do 5-6 70mph to 20 HARD stops and then drive gently for a ten minutes. That will break the glaze many times.
Ric in RVA
oolas3388.00
      09-23-2016, 01:08 PM   #6
oolas3
Check your regional forums for recommendations on reputable indy shops. This is not one of them.
      09-23-2016, 01:10 PM   #7
R3dliner
R3dliner's Avatar
Drives: 18 M3 6MT
yes and yes. They took you for a ride
      09-25-2016, 04:04 PM   #8
nick3753
nick3753's Avatar
1020
Drives: 2012 e92 M3 DCT ZCP
2017 Audi S6  [0.00]
1997 BMW 328i Touring  [0.00]
2012 BMW M3  [0.00]
Good opportunity for a DIY brake/rotor change and an even better time to teach your daughter to do it.
      09-25-2016, 04:08 PM   #9
Daftasabrush
Fool
Daftasabrush's Avatar
England
1857
Drives: F31 340i
Completely ripped off. As soon as I saw the word 'deglazed' in the thread preview, my thoughts were 'yup, he's been scammed'
      09-25-2016, 05:09 PM   #10
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
Wow, lol that is horrible
What you could've also done is buy the most abrasive pads (race/track pads) and run them through until the rotors look freshly machined, then install new pads. I did that to eliminate some brake and steering wheel shimmy issues too
      09-25-2016, 05:33 PM   #11
wdb
dances with roads
wdb's Avatar
4737
Drives: '07 E86, '02 996, '95 Seven
Uhmmm, 'glazing' causing squeaking? Is this a BMW thing? Because in the rest of the automotive world disk brake 'squeaking' is caused by vibration between the brake pad and the piston. Shims sometimes help, so does a bit of the right kind of grease.
      09-26-2016, 07:08 AM   #12
lowbudgethero
lowbudgethero's Avatar
125
Drives: '98 Z3M (gone), '09 135i
2009 BMW 135i  [8.50]
for that price your brakes and rotors should have been replaced
      09-26-2016, 09:38 AM   #13
Ric in RVA
Bergspyder
Ric in RVA's Avatar
Just redid my fronts and rears using an FCPeuro package on my 135i. Your 528 should be easier...and way cheaper:
https://www.fcpeuro.com/BMW-parts/52...79&m=20&page=1
From here on is 135i info.
https://www.fcpeuro.com/products/bmw...116778647ktfr3
FCP euro has lifetime WEAR warranty.....yes if you wear out a disc or pad they will replace for cost of shipping. I doubt that I would do since I think wear items are on me but it is good to know.
They are simple to do with no difficult issues at all.
You need a T40 torx for the front pads. A 10mm hex for the front calipers. Hex for the rotor retaining screw. (maybe a 6mm? I forget)
Rear you need 15mm (5/8ths works), a punch and hammer to drive out the pins.
Piece of cake.
While you are down there bleed the brakes. Good training for the kids....pumping the brakes so dad can bleed them.
I have to say the 135i front calipers are light and gorgeous when off and cleaned up.
Ric in RVA
      09-26-2016, 09:52 AM   #14
Torgus
Slow.
Torgus's Avatar
Drives: Single Turbo N54 on Meth!
2007 BMW E92  [10.00]
2007 BMW E90  [0.00]
2006 BMW E91  [0.00]
If you have to ask...
      09-26-2016, 10:14 AM   #15
kpeng
Drives: F30 M-Sport + E30 Super ETA
I just poured out a beer for you.
      09-26-2016, 10:16 AM   #16
Torgus
Slow.
Torgus's Avatar
2007 BMW E90  [0.00]
2006 BMW E91  [0.00]
hopefully into a glass.
      09-26-2016, 10:27 AM   #17
kpeng
Nah man, on the ground, like for when people die.
      09-26-2016, 10:37 AM   #18
tdott
Drives: M3
Did you approve that work to be done?
I would never approve anyone that recommended machining rotors. Then again, I probably would have just fixed the problem myself. You could have done new brakes all around for less than $300 with quality parts.
      10-10-2016, 05:14 PM   #19
ericbikes
Drives: 2000 528i
I did not approve the work. I told him to look at the front brake that's squeaking and let me know what he finds/thinks. I agree that for the money he charged I would have replaced all 4 rotors and pads. The FR PageID pads are new, but the rear JURID pads are old and sanded down (he charged me $95 for these pads). Total ripoff. I paid for some of the work and sent him registered letter that I did not approve all the brake work. I still overpaid and chalked it up to learning my lesson about this shop. Any good suggestions for rotors and pads? I recently re-did the brakes on my Cherokee with Powerstop and I'm not sure I like them.
      10-10-2016, 05:18 PM   #20
shoguniori31
shoguniori31's Avatar
Drives: 2016 Bmw 428i MT
yup without a doubt. Those pads looked horrible
      10-19-2016, 10:57 PM   #21
Steve50
Drives: 2009 BMW X5 e70 4.8i
Yea, I'd say you got screwed on that one.
      11-06-2016, 09:31 PM   #22
2M
2M's Avatar
Drives: Mineral Grey M2
Thats what it costs me for 4 new pads/rotors + a brake fluid flush; labor included
E9X Picture Game: 8 points: (High visibility jacket; Strip Club; Pizzeria; Sobriety Test; E9x dressed for Halloween, Billiards, Oil Change, Orange Cone)
