Go Back   BMW E39 5-Series Forum | 5Post.com > BMW 5-Series (E39) Forums (1995 - 2003) > General E39 Discussions
      08-03-2010, 02:23 PM   #1
modbargains
modbargains's Avatar
170
Drives: 08 E90 335i & 01 Toyota Avalon
**********s | FORGESTAR F05 GROUP BUY *UP TO 325.00 OFF*
**********s and Forgestar team up to offer you HUGE SAVINGS on the Forgestar F05's
[IMG]http://www.**********s.com/images/Products/Front_banner/Colored%20Banner.jpg[/IMG]
FLOW-FORMED, LIGHTWEIGHT, AND COMPLETELY CUSTOM TO YOUR CAR'S SPECS!
*GROUP BUY SPECIAL PRICING*
5 SIGNED = $175.00 OFF
10 SIGNED = $250.00 OFF
15 SIGNED = $325.00 OFF
*GROUP BUY ENDS ON 8/20/2010
Contact Kevin directly at ************** ext 8009 or E-mail Kevin************.com for the details!
Available Finishes
GLOSS BLACK WITH POLISHED LIP
[IMG]http://www.**********s.com/zoom_img/_1241538490.jpg[/IMG]
BLACK and BRUSHED TWO-TONE WITH POLISHED LIP
[IMG]http://www.**********s.com/zoom_img/_1241538633.jpg[/IMG]
GUNMETAL WITH POLISHED LIP
[IMG]http://www.**********s.com/zoom_img/_1241538608.jpg[/IMG]
About Flow-Forming
Forgestar's flowforming process is a unique solution to a common problem – how to make a wheel both light and strong.
This specialized process begins with a low pressure type of casting and uses a special machine that spins the initial casting, heats the outer portion of the casting and then uses steel rollers pressed against the rim area to pull the rim to its final width and shape. The combination of the heat, pressure and spinning create a rim area with the strength similar to a forged wheel. During Flow Forming, the pressure applied to the cast rim actually changes its mechanical properties, so its strength and impact values become similar to those of a forged rim. That translates to up to 15% less weight when compared to a standard cast wheel. The resulting grain structure within the alloy of the wheel is linear, flowing in a single direction.
This grain structure pattern, combined with the exceptional quality of casting required for the process, gives the rim area of the wheel huge mechanical strength, and elongation. As a result of these mechanical characteristics, Forgestar is able to reduce the thickness of the rim area resulting in reduced weight, without compromising strength and resistance to impact.
So in a nutshell, the process makes the wheels:
  • Almost as strong as forged wheels
  • Lighter than cast wheels
  • Customizable to a range of offsets and bolt patterns
  • A great value for the price
Forgestar's Latest News
Forgestar has more recently purchased over 2000 barrels and has purchased additional CNC machines to cater to the high demand for the wheels. With that in mind, you should expect a set of wheels to be completed in a 4-6 week lead time!
*PRODUCTION EVERY OTHER DAY*
