Go Back   BMW E39 5-Series Forum | 5Post.com > BMW 5-Series (E39) Forums (1995 - 2003) > General E39 Discussions
      10-31-2014, 01:02 PM   #1
fourtailpipes
Drives: the ladies crazy
e39 washer issues
i have a 1999 e39 530d banger i keep at a beach house in sicily. i got it for a song with ~350,000km on the clock, and i pretty much consider it disposable. on my drive this morning i noticed that no washer fluid is coming out for the windshield, but IS coming out for the headlight washers. i opened the hood and was surprised to find that since i was last here in the summer, some kind of small rodentia must have moved into the engine compartment and ate a large portion of the "intensive" washer fluid tank. yes... ate the tank. the normal tank seems not to be leaking, and is full.
can i simply delete the "intensive" tank entirely? the pump in the now eaten intensive tank appears to still be responsive, and is the same part number as the wash pump used for supplying the windshield from the primary tank in the wheelwell... is there any reason i couldn't replace the (i suspect) failed windshield pump with the (i suspect) functional pump from the intensive tank?
      11-01-2014, 04:37 PM   #2
fourtailpipes
wow, not a lot of activity on this forum! is there anywhere else i could ask? i'm hoping for a vote of confidence before i attempt the job, since it'll cost me some valuable beach time.
      11-11-2014, 04:39 PM   #3
GuamX1
GuamX1's Avatar
Guam
28
Drives: 08 BMW 135i, 08 128 Cab
I think you can it is independent of the regular washer system.
2013 BMW X1 * 1973 Clubman GT * 2016 Mazda MX5 * 2000 Honda S2000
2004 BMW 325i Touring * 2009 BMW X5 3.0xdrive
      01-11-2015, 07:54 PM   #4
Paul Ho
Drives: F10 M5, E39 M5
If the setup is the same as on my 2000 M5, there are parallel hoses that go to the nozzles on the hood. You will have to either plug the hoses that go from the intensive pump or replace the nozzles with ones from a car without the intensive cleaning system.
