E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Need a new clutch
Reply
      02-13-2017, 02:53 PM   #1
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
Need a new clutch
My indy is suggestion that I might have a problem with my clutch and/or pressure plate.
Common?
I haven't noticed anything in particular about the way the car has driven/drives, and no noises
And if I do - where can I get a good kit?
FYI - I don't drive hard at all. So I'm not interested in more clamping force when I won't use it.
      02-13-2017, 04:35 PM   #2
W37V
[Oo=||=oO]
Drives: e92n52 & f15n57
Why did he make such suggestion? Is your clutch slipping? What's your mileage? Depending on mileage, you might want to consider replacing your DMF. They do go bad occasionally.
You can get whatever BPC got when they broke theirs. If it is able to hold up turbo power, I don't think it should have much issue holding up to plain ol' NA n52.
Taskmaster2465.00
      02-13-2017, 04:53 PM   #3
tlow98
Drives: 2009 E91, 2014 F15 x35i
Strange. If it's not slipping or engaging weird or the TO bearing isn't making noise I don't think I would replace it.
If you do replace it, use the stock 330i unit. It's beefier than the 328i and all OE.
Taskmaster2465.00
      02-13-2017, 05:03 PM   #4
justpete
Drives: '11 328i '19 M6
2019 BMW M6  [10.00]
2011 BMW 328i  [9.00]
Common?
Personally, I'd get a second opinion.
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
      02-13-2017, 05:22 PM   #5
AWSB328iM
AWSB328iM's Avatar
Drives: 2011 E92 328i M-Sport 6MT
What did they say the symptoms were? I've got 220k on my '97 M52 clutch. The clutch slave went at 215k. $65 later I was back on the road. I would say there is no need to change it unless there is a throwout bearing problem or dual mass flywheel problem. I truely believe these clutches can last 250-300k if the owner drives the car properly and doesn't track or do burnouts.
Taskmaster2465.00
      02-13-2017, 05:33 PM   #6
Taskmaster
Japan
2465
Thanks guys!
      02-14-2017, 09:27 AM   #7
Taskmaster
Japan
2465
BTW hassmaschine, what do you think?
      02-14-2017, 09:29 AM   #8
Taskmaster
Japan
2465
Are you sure it fits?
      02-14-2017, 08:40 PM   #9
Terraphantm
Drives: E46 M3 Coupe
I know of at least one person who's done so. Both cars use the same flywheel so it should all bolt up.
What made your mechanic suggest it in the first place? I have 150k miles on my M3 and 180k on my 330i - neither show any signs of impending clutch failure.
      02-14-2017, 09:34 PM   #10
hassmaschine
Drives: "NBO" 330i
Same engine/trans, why not?
My cars are both around 120k - clutches are still fine. I bet the DMF fails first.
Efthreeoh17309.00
      02-14-2017, 10:31 PM   #11
Terraphantm
Trans is actually different. 328s got the 325i transmissions. (GS6-17 vs GS6-37 in the 330). Still should fit though.
      02-15-2017, 06:38 AM   #12
Noir
Noir's Avatar
Drives: 2006 E90 330i 6MT
+1
Getting mine looked at/replaced this week because it is actually slipping-
Minimal slipping at that, but nipping it in the butt now before it hurts anything else. Particularly the flywheel.
      02-15-2017, 03:25 PM   #13
Taskmaster
Japan
2465
Ok, going to grab a 330i clutch (same as the 328xi clutch)
      02-15-2017, 06:37 PM   #14
330iE90
Drives: e90 330i
Yeah the DMF will fail first. There are multiple reports of it failing prematurely even at lower mileage. I got a DMF click/rattle already 117k, clutch is fine.
      02-16-2017, 10:39 AM   #15
desertman123
E82 Mudflap Ambassador
desertman123's Avatar
Drives: '08 128i
1992 Honda Beat  [9.50]
2008 BMW 128i  [10.00]
2014 BMW 528i  [10.00]
https://www.ecstuning.com/b-valeo-pa...it/835115~val/
There's always this.
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded
Instagram @Andreys_128i and @Honda.Bito
David0ff1059.00
      02-16-2017, 03:07 PM   #16
Noir
Noir's Avatar
Things are happening today...
Was told the flywheel looks good, not beat to crap or anything-
Won't see the car till tmrw from what it is seeming but nonetheless, excited.
I have searched, but in your guys' opinion, best amount of miles for a break in period?
Figured I'd take the 500 miles I have left before my oil change- to break in the new clutch. (Noooo, I'm not relating my clutch to oil, just the easiest way to remember)
Input?
Sorry if I ...
      02-16-2017, 03:22 PM   #17
Taskmaster
Japan
2465
Input?
Sorry if I ...
500 miles is what I heard.
      02-16-2017, 03:24 PM   #18
justpete
2019 BMW M6  [10.00]
iirc it's in the manual for the car.
Taskmaster2465.00
      02-16-2017, 03:25 PM   #19
Taskmaster
Japan
2465
Ahhhhhh!
      02-16-2017, 03:26 PM   #20
Noir
Noir's Avatar
I have it in my glovebox now that I think about it...
Sorry!
      02-17-2017, 04:32 PM   #21
Noir
Noir's Avatar
Welp.
Got both my clutch and DMF replaced.
      02-18-2017, 01:28 PM   #22
Dan Bilzerian
Dan Bilzerian's Avatar
355
Drives: E90 325i 6MT
Welp.
Pretty expensive job? I'm hearing a squeal when I let out the clutch.. thinking it's probably time I replace mine.
I'm curious about the single mass flywheel though, that looks like a good option. Although I don't know anyone who's done it though.
Reply
e90post
