12-17-2016, 01:12 AM | #156 |
Rep 24
It's not. It's a high quality copy apparently sourced from the same if not similar automotive suppliers.
//Stable_2017 BMW M2///1984 Porsche 911 3.2 Carrera///2012 Toyota FJ Cruiser///2012 Ducati 1199 Panigale S///2015 Honda Grom |
12-18-2016, 06:59 AM | #157 | ||
Law Enforcer
25022
Rep 22,269
Posts Drives: '22 Chalk Gray Porsche C2S Join Date: Jun 2006
12-20-2016, 12:58 PM | #158 | |
Rep 798
If you feel comfortable, you can send me a set of key fobs and we can work on it before you come up north. |
02-10-2017, 09:03 AM | #160 |
Captain Crunch
168
Rep 548
Any updates from MFNATIK or iczer34 ? I'm very interested in this and if we have another confirmed case, I will try to have this done locally.
On Order (in transit): BMW iX 50, Oxide Grey
Retired: BMW Welt Delivery 4/14/16: European Delivery - 2016 340i EBII/Saddle - ZMP | ZCW | ZDA | ZLP | ZTP | M Adaptive | Rear Shades | MPPSK Before and After Dyno Retired: 2011 335D Space Grey/Black - ZSP | ZPP | ZCW | 6FL | Sat Radio | Nav | $600 Base Audio Upgrade |
02-10-2017, 11:34 PM | #161 |
"The Midas Touch"
519
Rep 1,055
Posts Drives: F87 LBB ///M2 Join Date: Aug 2007
02-11-2017, 12:53 AM | #162 |
Blocked from G80/G82 for having an opinion
3498
Rep 3,729
02-11-2017, 12:51 PM | #163 |
"The Midas Touch"
519
Rep 1,055
Got my key today. Anyone have instructions on how to open the stock key? Got the new key open as it was pretty straight forward. Having issues with the stock key.
02-13-2017, 11:43 AM | #164 |
Rep 165
I wana ship mine if anyone knows how to do it.
BMW M5 | Singapore Grey | Sakhir Orange | Turner Muffler Delete | Alpha Catless Downpipes | RamAir Intakes | ESS Tune E-700 | Performance Front Lip | Performance Wing | Stance SF07 20X9(20ET) 20X10.5(27ET) |
03-16-2017, 10:21 AM | #167 |
Rep 165
any updates? i have a key awaiting? if not ill sell it someone can try it
03-16-2017, 01:10 PM | #168 |
Rep 812
Get a rotary tool (Dremel) and a thin cutting wheel. Pop out the metal key. Make a small cut where the two pieces meet and then you can pry it be rest of the way off (it's epoxied together, not snapped together like most keyfobs). This is the only way that I've found to split the two halves cleanly.
2016 Azurite Black F80 6MT
04-21-2017, 08:18 AM | #169 | |
Rep 72
According to my deep research and some chat with the suppliers, these keys support 315 mhz keys only and newer ones support 315 mhz and 434 mhz. If you happen to have a regular F30 car with the 868 mhz key, unfortunately it doesn't work. |
04-24-2017, 11:06 PM | #170 | |
Rep 560
06-23-2017, 07:25 PM | #171 |
Rep 13
So I did this mod successfully to my F10 M5, some details for anyone who plans on doing this themselves:
You need to swap both black chips, not just the one circled. Make sure the key you buy matches the frequency of your key, in my case I had a 315mhz key so that's what I bought. To cut the key blank, most locksmiths won't have the setup to do F series BMW Keys, so have them cut it as a 2016 Chevy Impala key (weird I know, but it worked for me. As always, YMMV) My research also shows that tools exist to program the fob after dumping the CAS flash to get the encryption code, then writing that to a blank key. It's unknown if this will work with the retrofit key, but if someone has the tool I'd like to work something out to give it a try. One I found that could possibly work is an AK91+ key writer, but I don't plan on purchasing one. For those local to south Florida, PM me if interested in being part of a group buy for the blade fob. Once I figure out the forum rules regarding a group buy, I plan on doing a forum wide one around August/September, where people would ship me your spare keys and I have my technician and locksmith down here swap the chips and cut the new blank. Your old key case will be lost in the process, as the case is ultrasonically welded closed and must be cut open to remove the circuit board. |
06-24-2017, 05:19 PM | #172 | |
Rep 154
07-06-2017, 12:47 AM | #174 | |
Back in the BMW family
43
Rep 406
Too much to list......
07-14-2017, 02:59 PM | #176 | |
Rep 139
