01-26-2018, 06:56 PM | #860 | |
Get off my lawn
932
Rep 1,159
Drives: 6MT
Garage List 2023 GR Corolla [0.00]
2022 BMW X3 M40i [10.00] 2007 BMW Z4M Coupe [0.00] 2002 BMW 325xiT [0.00] 1991 BMW 318is [0.00] |
2. I wholeheartedly agree. 37K miles of 228i ownership and seat time in the M235i and M2 has shown how big of a factor engine placement and balance can make. Glad to see BMW continuing the Z4 platform, but it has lacked any real character since 2008. I am hopeful that the BMW & Toyota partnership brings a car more similar to the M2 / FT-86 than the recent E89 Z4 / RCF. |
M3 Adjuster7905.50 |
01-29-2018, 09:38 AM | #862 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
The E85/6 have similar wheelbase as the E89. The front and rear overhang had both grown on the Z4 in each subsequent generation if the technical drawings are all we have to go on.
The 5er for sure have a significant front overhang growth. |
01-29-2018, 07:06 PM | #863 |
1821
Rep 5,337
You know, if BMW just did NOTHING but to bring the E85/6 chassis back, I think we'd have a winner.
Just throw the new engines and transmission under the hood, use the existing E85/6 suspension front and rear and be done with it. 12 years later this car still look BETTER than most of BMW's offering today IMO. I'd take this over the G29 any day.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
01-30-2018, 10:51 AM | #864 | |
Rep 887
GC LITES / BQ TUNE / MHD / FUEL IT BT ECA / WALBRO 525 LPFP / KW V3 / E9X M3 CONTROL ARMS / TURNER REAR CAMBER ARMS / RE BUSHINGS / H&R SWAYS / LUXON STRUTBAR / VRSF 7.5" FMIC / ER CP / TIAL BOV / VTT IN/OUTLETS / AFE PRO5R INTAKE / AR C.L. DP / BMS OCC / RB PVC / CF LIP + SIDE + SPOILER + DIFFUSER / IND REFLECTORS / BLK GRILLS / STUBBY / PB BBK / Forgestar F14 F: 19x9 et35 R: 19x10 et38/ Michelin PSS F: 245/35/19 R: 275/30/19
01-30-2018, 10:51 AM | #865 | |
Rep 2,335
The Z4 looks like it gain the most overhang from the rear. Again, that photo you posted of the blue coupe flavors the rear and makes the front look super short. |
01-30-2018, 06:52 PM | #867 |
1821
Rep 5,337
What?! According to the technical diagram ALL the growth in the overall length came in the front overhang. The new 5er is 26mm longer overall, and the front overhang is longer by 26mm. Basically the rest of the car stayed, and all the length is added up front.
01-30-2018, 07:04 PM | #868 | |
Rep 2,335
Same goes for the Z4. Differences is 27mm, or 1.06 inch. Now the rear gained 120mm or 4.2 inches. |
02-01-2018, 10:48 AM | #869 |
1821
Rep 5,337
I keep telling my wife that.
The problem isn't that it's just an inch (gawd I can't keep a freakin' straight face typing that), but where that inch is and what percentage of that is the growth in the overhang. That's 3% of the overhang. Say each subsequent generation grows another 3%, compounded in 3 generations that growth will exceed 12.5%. The G28 is already 2 generation removed from the E85/6, and as we can see in the G29, the front overhang growth is likely more than 10% compared to the E85/6. To my earlier point, the problem with the growing front overhang is where the engine is placed in relation to that front axle, and the amount of room available for caster angle. If you've ever had the luck to drive an MZ4 vs. E46 M3, and drive it angry, you'll immediately notice that the MZ4 had incredible front end response. That steering is telepathic. It does whatever you tell it to (whether it's good or not) and tells you exactly what it's doing. The MZ4 and the E46 M3 share a ton of parts, for the MZ4 to be THAT much more responsive up front has quite a few reasons (200+ weight differential, shorter wheelbase, E36 M3 based steering rack...etc). But primarily it's because the S54 sits a few "inches" further back of the front axle on the MZ4, and because of that, the MZ4 had the luxury of having SIGNIFICANTLY more front caster than the E46 M3. I was fortunate enough to own an MZ4 Coupe, Z4 3.0i, E46 323Ci, and a Z3 1.9L, and I'll tell you this. You can't beat having the engine as far back as possible on a front engine design, and you can't beat massive caster angles on a MacPherson Strut based front end on a sports car. That caster angle creates camber changes and improve weight transfer while cornering. Here's another example: These are static shots (car's not moving) of a corner balanced MZ4 Coupe. Notice how much LOWER the driver's side is compared to the passenger side (look at the wheel gap)? It's because the massive front caster forces the outside (driver's) suspension to compress while lifting the inside (passenger's) suspension*. This is the biggest benefit of continuing to push the front wheels out as far as possible and keeping the front overhang as small as possible. You can put massive caster on a MacPherson strut that causes this natural static camber change as you turn. 2º of additional caster on the E85/6 chassis over the E46, only achieved by minimizing overhang and pushing the engine as far back as possible. While this discussion is all "academic" at this point, since BMW has already done the bulk of their chassis development for the G29. The problem points to a larger, overall trend within BMW itself, that they've continued to compromise sporty handling for more "comfort," to a point that these newer chassis are cruisers first, carvers second. * The E86 chassis is so gosh darn stiff (32,500Nm/º of deflection) that raising the front suspension also raises the rear suspension. You can tell from the shot that the entire passenger side sits higher, both front and back.
Remonster824.00 |
02-04-2018, 08:19 PM | #870 | |
Rep 2,335
Some's mind went into the gutter.
This is all I know about the topic on hand. Quote:
02-06-2018, 05:41 PM | #871 |
Rep 21,240
Update: February 6, 2018
Here are some of the most detailed information yet on the Supra (and in effect, the G29 Z4), just posted by trusty source ynguldyn. • Three engines (EU-only 195hp 20i, 255hp 30i, and 335hp 40i - and this means the 380hp Z4 M40i will be offered only by BMW and only in North America and a few other non-EU markets).
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
02-06-2018, 05:45 PM | #872 |
Rep 4,567
Autotragic only ?
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem |
02-06-2018, 06:28 PM | #876 |
In The Rain
8174
Rep 6,259
Drives: '24 GT4RS, '24 Macan GTS
I like the concept more. It's more angular, production seems too round... hm
'24 Porsche Cayman GT4RS Arctic Grey "Alice"
'24 Porsche Macan GTS Dolomite Silver "Gina" |
02-06-2018, 08:09 PM | #880 |
Rep 9,134
