Go Back   BMW E39 5-Series Forum | 5Post.com > BIMMERPOST Universal Forums > Site Related Announcements - Suggestions - Feedback - Questions
      03-12-2018, 01:33 PM   #1
bimmer456
Drives: 340i
Blue bar above rep count on left pane in app
So what is the blue progress bar measuring?
      03-12-2018, 01:36 PM   #2
Lups
Lups's Avatar
11829
Drives: I don't own a car.
The more reps you collect, the more it goes to the right and turns red. They're trying to tell the popular kids they're cool while making others blue.
Originally Posted by Joekerr View Post
You're still a little new here, so I'll let you in on a little secret. Whenever Lups types gibberish, this is an opportunity for you to imagine it to be whatever you'd like it to be.
Originally Posted by Delta0311 View Post
How would you know this? Did mommy catch you jerking off to some Big Foot porn ?
      03-12-2018, 02:40 PM   #3
apptest
Private2
apptest's Avatar
Drives: BMW M3 F32 Coupe!
If it's around the middle, your rep score is around the average, if it's more to the right of middle your score is above average and more to the left you are below average.
Test 23456rt
      03-12-2018, 02:41 PM   #4
apptest
Private2
apptest's Avatar
Everyone is blue on the app
Test 23456rt
      03-12-2018, 02:48 PM   #5
Lups
Lups's Avatar
11829
I'm working on my reading skills, I missed the app word!
You need to add some colors and then we can do a rerun to this!
I tried saying sorry, my bad but I'm allergic to those words.
      03-12-2018, 02:56 PM   #6
G35POPPEDMYCHERRY
G35POPPEDMYCHERRY's Avatar
Drives: F80
1000+ rep <30 posts. Still not in red!
Lups11828.50
      03-12-2018, 03:00 PM   #7
apptest
Private2
apptest's Avatar
I exist to test and develop the app. My points are all artificial to test things
Test 23456rt
      03-12-2018, 03:07 PM   #8
bimmer456
Drives: 340i
It says 439 on yours. Or you meant him my bad.
      03-12-2018, 03:12 PM   #9
Dackelone
European Editor
Dackelone's Avatar
Germany
10642
Drives: N54 e82
Rep Points...
Just cross posting this for the next person to ask why their rep points have gone down or are fluctuating from day to day.
Loss of Rep Points...
http://www.1addicts.com/forums/showthread.php?t=1472480
Dackel
      03-12-2018, 04:13 PM   #10
G35POPPEDMYCHERRY
Drives: F80
just stirring the pot.
good work so far on the rep system.
Nomana1471.00
      03-13-2018, 04:20 PM   #11
Nomana
Nomana's Avatar
1471
1000+ rep &#60;30 posts. Still not in red!
Nice work.
Btw you are app developer or BMW enthusiasm or both sir?
      03-13-2018, 04:35 PM   #12
G35POPPEDMYCHERRY
Drives: F80
Originally Posted by Nomana View Post
Nice work.
He is The Architect father of the matrix
      03-13-2018, 09:59 PM   #13
apptest
Private2
apptest's Avatar
Test
Test 23456rt
      03-14-2018, 11:57 AM   #14
DBACE
DBACE's Avatar
Drives: F80 M3 LCI
2016 BMW M3  [10.00]
2005 CBR1000RR  [10.00]
1995 ST1100  [9.00]
2009 Camry Hybrid  [0.00]
Smile The Bar is Showing Standard Deviations
OP, The bar is showing actual standard deviations (SD). Light Blue if you are <1 SD, Dark Blue if you are <2 (SD), Red if you are <3 (SD). Obviously if the bar is full with all three colors than you get the >3 standard deviations note.
In statistics, the standard deviation (SD, also represented by the Greek letter sigma σ or the Latin letter s) is a measure that is used to quantify the amount of variation or dispersion of a set of data values.
Think of a bell curve used on a chart to represent data, the target is the peak of the bell. In some cases, like a high volume production line, you want to hit the peak or target every time. Anything higher or lower means a defect in your product. "All variance is evil". Companies would react to the quality indicator and take action to get back on target by changing out wearable items in the production line equipment, or change a tool, process, etc. So, if your production line of animal crackers is running on a six sigma level (meaning you can go -3/+3 (SD) from target, you would have some absurdly low error rate for every 1 million crackers made.
In Bimmerpost's usage they are taking the whole population's average and setting the peak at the start of the curve to score how many standard deviations away in a positive direction from the average you are. (using a half bell curve, since you can't go negative with rep points).
It would be interesting to see the shape of the Bimmerpost bell, which I presume changes with membership numbers, and I would imagine changes the area value (or percentage) of an actual standard deviation. I think....
Here is an example of a bell curve used with standard deviations, to give you an idea of what I am on about. I hope it helped you along with what others are saying.
F80 ///M3 LCI SSII
Lick the lollipop of mediocrity once and you suck forever.
      03-14-2018, 02:07 PM   #15
bimmer456
Drives: 340i
Lol is it really that complicated?
      03-15-2018, 02:43 PM   #16
DBACE
DBACE's Avatar
Drives: F80 M3 LCI
2016 BMW M3  [10.00]
1995 ST1100  [9.00]
Smile Maybe It's Even More Complicated
I am inclined to think it is even more complicated in this case. You yourself have a rating that is more than 1 standard deviation, which according to the Bimmerpost formula is in the top 15% of the population. Since Reputation points are measured in a positive direction only (no negative Rep points), the software ignores the possibility of a negative score, yet tells you where you lie in a standard deviation on a bell curve that includes the possibility of a negative score.
I am sure one of the moderators can better explain the whole thing and in simpler terms.
F80 ///M3 LCI SSII
      03-15-2018, 08:06 PM   #17
Mark's Avatar
6750
Drives: 1M
Thanks for explaining it. It is a little more complicated only because we have a bimodal distribution of the population (alot of post whores and alot of people with 0-10 reputation) so we have a very large SD.
The other thing is you assume that a bell curve or any population distribution needs negative numbers and so a half bell is used? You don't need negative values to create a population curve. We simply do not display the negative SDs to people since it would not be as informative due to our non standard population distribution.
In the end its almost to the T how you explained it in the first post except we have some tweaks to account for our population distribution and we also take into account relative activity (surfing, etc..)
DBACE690.00
      03-15-2018, 08:27 PM   #18
IK6SPEED
Drives: BMW M3 / AH3
What blue bar
      03-15-2018, 08:42 PM   #19
DBACE
DBACE's Avatar
Drives: F80 M3 LCI
2016 BMW M3  [10.00]
1995 ST1100  [9.00]
And there it is....
@Mark Thanks for stepping in and clarifying. I personally would love to see the shape of the curve. Can it be posted? Again thanks for all you and others like you do for the forum. I appreciate the work all of you put into it.
F80 ///M3 LCI SSII
      03-15-2018, 08:48 PM   #20
DBACE
DBACE's Avatar
Drives: F80 M3 LCI
2016 BMW M3  [10.00]
1995 ST1100  [9.00]
Depends on the Application you Use
Originally Posted by IK6SPEED View Post
What blue bar
This bar right here........you see it in a web browser, but not on the IOS Application for Bimmerpost.
F80 ///M3 LCI SSII
IK6SPEED4499.00
      03-15-2018, 08:53 PM   #21
IK6SPEED
Stupid me for believing the OP.
Can I give negative rep, lol.
DBACE690.00
      03-15-2018, 09:16 PM   #22
apptest
Private2
apptest's Avatar
The blue bar is in the app, its right under your username in the left hand menu pane
The colored bar (blue to red) is on the web forum
Test 23456rt
DBACE690.00
