06-13-2018, 07:04 PM | #23 | |
Rep 4,139
edit: maybe on 0 humidty days blow the ducts out? |
06-13-2018, 07:14 PM | #24 | |
Rep 14,115
Posts Drives: G82 M4C X-Drive Join Date: Mar 2013
Another great tip is to not leave wet clothes in the car and use weather proof mats that you can wipe down when you leave the car.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
05-01-2019, 03:42 PM | #25 |
Rep 34
The climate control function can be controlled as part of your seat and mirror memory setting. Next time in the car, with the key fob you use, ignition on, set everything the way you want it. The climate control should be turned OFF. Then, hit SET, then hit which ever memory button you use, 1 or 2, then hit Set. The next time you start the car, it should start with the climate control off.
05-01-2019, 03:56 PM | #26 | |
Rep 433
05-01-2019, 03:58 PM | #27 |
Rep 1,031
Posts Drives: Like a bat out of hell. Join Date: Apr 2019
Leave everything to automatic, set your temperature and forget about it. I even set the re-circulation mode to auto. It's supposed to close off the fresh air vent if there's an overabundance of particulate. Modern cars are practically airtight and you should have fresh air make-up for the cabin anyway.
