11-08-2016, 06:01 PM | #1 |
Rep 2,476
Posts Drives: Satan's Chariot 2.0 Join Date: Sep 2013
Cannot get MS Office to work properly!!
Never had any problems like this before, but no matter what version (2010, 13 & 16) it will install fine & work fine at first, but then when I restart the computer, it will go through office setup every time no matter what.
I've tried several valid files from torrents as well as a legit Office '13 from work & it does the same bs every time. Anyone have this issue before? How did you fix it? |
11-15-2016, 06:46 AM | #3 |
Rep 2,476
11-15-2016, 09:41 AM | #4 |
Rep 623
Completely remove all versions of Office from your computer. Not just uninstall, but after uninstall remove all Office folders and registry settings. May have to download Microsoft's uninstall utility to completely remove. Do a fresh install.
Steve |
11-17-2016, 09:42 AM | #5 |
Rep 256
I moved to Libre Office, a free open-source MS Office alternative. The files are 100% compatible as well. The only issue I have is that I cannot open my archived Outlook PST files within Libre Office, but I have a VM that has office installed for that if needed.
Current:
2019 911 targa 4 | GT Silver Metallic 2019 X3 M40i | Glacier Silver Past: 2013 911 C4S | 2019 X2 M35i | 2015 M5 Comp | 2013 M5 | 2013 640i | 2010 535xi | 2007 525xi |
11-17-2016, 12:50 PM | #6 |
Schmollbraten
12509
Rep 1,985
Delete your whole office files, folders, settings and clean the registry.
After that make an offline installation of the desired office version, that worx although some ppl state it dont. After that you have to replace one or two certain *.dll files and when you then after reboot connect the www you should encounter no failures with you hijacked version. But as recommended previously, OEM is the best and to close my 50ct here: No, I wouldnt provide the necessary files.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
12-01-2016, 05:56 PM | #7 | |
Rep 2,476
Also, once again, I have tried an OEM version & had same results!!! |
12-01-2016, 08:12 PM | #8 |
powerhouse
708
Rep 1,628
Posts Drives: 2014 Porsche 981 CS Join Date: Feb 2011
Also, check the startup applications to see if there's something weird going on at boot.
If that doesn't work; mount and roger.
no signature. except for this one.
