02-15-2017, 02:53 PM | #46 |
Baby-faced Assassin
1203
Rep 152
Posts Drives: when car isn't broke. Join Date: Sep 2015
02-15-2017, 03:18 PM | #47 |
Rep 685
As a landscaper go with the 6x6. I've seen a huge difference in the amount of time they last compared to 4x4s. You'll save the money in the long run if you plan to stay long. That neighbor needs to fix his lawn, that doesn't help the fence either. Water splash is no good plus the turf will suck up moisture.
02-16-2017, 10:47 AM | #48 |
18001
Rep 9,378
Hey jgoens are you set to get as much water as they are telling us for this weekend? We are hearing 3-6 inches Friday/Sat here locally. Dang, we only get 11 in an average year. . . glad I already sent that check to FEMA again this year!
02-16-2017, 10:50 AM | #49 |
Rep 5,776
Sounds like you guys get a turn in getting a dumping--you need it more than us--there are three storms coming in(one of them is here now) but they are supposed to be light delivering a few inches at best. Yeah, for you guys 6 inches translates to get the canoe out.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
02-16-2017, 10:52 AM | #50 | |
18001
Rep 9,378
No canoe, but when it gets high enough the longboards will float free. Should have bought that new fishing slicker already . . . |
02-16-2017, 12:02 PM | #51 |
Rep 685
Most likely they will be using an auger and might not have the right size to make a hole big enough to allow room for concrete. Plus I know I hate when people buy materials for jobs, just another step that can cause delays.
02-17-2017, 10:48 PM | #52 |
Rep 11,722
What I would recommend is to build a 3 feet wall cinder block wall, and add some wood bolted on top. You can stain it, or leave it as is. This won't break the bank, and leaves it stylish.
02-17-2017, 10:50 PM | #53 |
Rep 5,776
Good idea. Can you bolt things to cinder block?
02-17-2017, 11:05 PM | #54 |
Rep 11,722
Of course. I've seen a wall being built at a winery, The contractors bolted a 2 x 4 laying on top of the cinderblock wall and then added the wooden fence wall to it. Or you can do something like this:
Or you can add vinyl fencing on top which will also look good. |
02-17-2017, 11:08 PM | #55 |
Rep 8,852
Posts Drives: '15 SO M4/'20 Z4 M40i Join Date: Jul 2014
A solid foundation wall can present a real drainage problem unless drain pipes are built into them.
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
02-17-2017, 11:14 PM | #56 | |
Rep 5,776
02-17-2017, 11:22 PM | #59 | |
Rep 8,852
02-17-2017, 11:53 PM | #60 | |
Rep 3,406
02-18-2017, 12:26 AM | #61 | |
Rep 5,776
