01-04-2018, 03:32 PM | #89 |
Rep 9,160
Can we agree that this V8
[IMG]https://static.carthrottle.com/works...8d51629793.jpg[/IMG] Will almost certainly out handle this V6? [IMG]https://icdn-6.motor1.com/images/mgl...irst-drive.jpg[/IMG] And why do I suddenly want an LSx S2k? |
01-04-2018, 04:42 PM | #90 | ||
Libertarian
71934
Rep 4,035
The E30 M3 was designed for the FIA's homologation.. FIA ( La Fédération Internationale de l'Automobile) Quote:
When all cars are modified, similar horsepower, all of sudden, better designs, lighter cars do better. |
01-04-2018, 05:41 PM | #91 | ||
Libertarian
71934
Rep 4,035
Lookbat the gap between both engines and the radiator. |
01-04-2018, 06:45 PM | #92 |
Rep 9,160
Gap from the radiator to the front of the engine doesn't mean anything aside from one can accept a longer engine (like an I6.) The E30 still had the engine further forward (and those scary/fun rear trailing arms.)
01-04-2018, 07:39 PM | #93 |
Rep 5,577
Look at the caster of the e30 strut mount, be interesting to see how the engines align with wheels centerline.
01-04-2018, 08:38 PM | #94 |
Libertarian
71934
Rep 4,035
Exactly, good catch!
01-04-2018, 08:45 PM | #95 | |
#buildnotbought
10859
Rep 4,893
If an average strut is about 30" long the shift of the strut tower backwards is easily calculated. Actually I'd like to see anglo do that, as he seems to know everything once people tell him how everything works Basic trigonometry
01-04-2018, 09:34 PM | #96 | |
Libertarian
71934
Rep 4,035
You want the weight between axles not over the axles for optimal handling. Contrary to what you think, the FIA's rules were on displacement not number of cylinders and DTM just followed FIA's classing and rules. You need google your points more carefully! Hahaha |
01-06-2018, 08:29 AM | #97 | |
Rep 18,737
bobert858.50 |
01-06-2018, 08:50 AM | #98 | |
Rep 18,737
That said, let's not get into the Subie WRX I was chasing last night on the way home from work. It was fun to see how well my E90 could keep up on a great back country road (no traffic) against a front weight imbalanced AWD performance car; it was purely for scientific reasons of course
01-06-2018, 11:05 AM | #99 | |
#buildnotbought
10859
Rep 4,893
I'd say thats spot on! Maybe if the washerfluid tank is half empty its 50/50
01-06-2018, 11:07 AM | #100 | |
Rep 18,737
Okay, I'm off to drop the fuel tank in the Hummer. If I'm not back in a while, my fire extinguisher failed.
GuidoK10858.50 pokeybritches479.00 |
01-06-2018, 01:16 PM | #101 |
Curmudgeon and Pedant
690
Rep 3,489
IMO, all the discussion regarding "handling" and 50%/50% is off base.
While a 50/50 makes for a nice neutral handling car with good performance, it's mainly a benefit for the more common daily driver than for race cars. Let's not forget that a mid-engined layout is readily acknowledge as the best for real performance and handling (even Porsche recognizes that fact and has limited power in the Cayman so that the older rear-engine chassis still wins out.) Frankly, my NSX (still miss that car), with it's 60-degree V6 ripping to 8K redline handled much better than my son's E92 335i (which is just as fast as the NSX, btw). Let's not forget that F1 cars use the engine (V6/V8) as a structural element, holding the front cockpit and front suspension together with the rear end. A V6 is far superior in that layout than an I6 could ever be. You can also point out the spec racing that took place in the E46 era, pitting a 320i against Acura/Honda and a couple other spec racing cars. The BMWs actually didn't do very well against the others, even though all the others were front-engined. |
01-06-2018, 02:45 PM | #103 | |
#buildnotbought
10859
Rep 4,893
Its not that an I6 block is less strong; you can make the walls/casting as thick as you want and in whatever shape you want.
01-06-2018, 07:32 PM | #104 |
690
Rep 3,489
Come on, now, you know the answer. A V6 is short and bigger in cross-section. Essentially it's a bigger and shorter beam than a long and narrow I6. Polar moment of inertia rules when it comes to stiffness.
01-06-2018, 08:32 PM | #107 |
Rep 9,160
01-06-2018, 08:57 PM | #109 | |
#buildnotbought
10859
Rep 4,893
And as for lenght, F1 raced with v12's for years, and they are as long as an I6. I think the main advantage is that in theory you can make a V6 lighter. But -putting it in the perspective of this topic- it does have to be made lighter. If you look at masses of V6 engines in normal cars, they are on average not really lighter than I6 engines. There are more valvetrain components etc that weigh in. And that can also translate in weight distribution. Like I said a z4 3.0si has a 50.1/49.9 weight distribution. Cars from the competition like for example a v6 equipped merc slk can not produce such optimal numbers. What in theory can be an advantage or not still has to be made in reality. I mean look at the current M3: thats also 50/50 (I think the exact numbers are 49.6/50.4). Mercedes c43 AMG (quickest v6 merc): front 55% - rear 45% The theoretical debate is interesting, but its the numbers in reality that determine it in the end. And reality is that a lot of v6 equipped cars have a worse weight distribution than bmw's with i6.
Red Bread4463.00 |
01-06-2018, 09:58 PM | #110 | |
690
Rep 3,489
Again, all this talk of even weight distribution is misdirected. A mid-engine design with around 60% on the rears and 40% front is by far the best handling design. 50/50 just isn't as quick in chicanes and in initial turn-in. |
The Choosey begger71933.50 |
