08-28-2009, 10:09 PM | #45 |
Mr. Nice Says Hello
638
Rep 16,662
Posts Drives: BMW M3 | X5 xdrive 35i MSport Join Date: Dec 2008
Subscribed
08-28-2009, 11:56 PM | #47 |
Rep 106
08-29-2009, 08:13 PM | #50 |
Rep 11,723
Sniz, great work mon amie. I don't know about S/C either. I used to own an '95 OBDI E36 M3. I purchased some goodies before I ended up w/ a Blower from Dinan. I had Schrick cams on it. When the Blower was added, torque wasn't readily available 'til like 4k rpm; which I was disappointed at, because when I drove a Dinan tuned '96 M3, the car was a jet off the line. That made me purchase the blower. Even my mechanic told me there is a lag and that we should remove the cams. He said the window of power moved quiet a bit. But upper power was a plenty. It pulled hard all the way to 165 mph (not going to say where I pulled that off )
GL w/ the "renewed" project. |
08-30-2009, 02:23 PM | #51 |
Rep 109
Posts Drives: 997 Turbo E90 M3 Join Date: Jul 2008
Garage List 2004 E55 AMG 卖 [0.00]
2010 BMW 128 卖 [0.00] 2007 BMW 335 卖 [0.00] 2003 Mitsu Evo ... [0.00] 2003 Porsche 911 Tu ... [0.00] 2014 Honda Accord V ... [0.00] 2013 BMW 335 xDrive ... [0.00] 2005 BMW M3 卖 [0.00] 2002 BMW M3 卖 [0.00] |
Awesome pics and thanks for the update bro.... I'll have to visit you guys at the garage sometime, I am in the college park area!
Is the engine built at all, head, bottom end, etc? What is the stock limit to the e36 engine under boost? What turbo system did it come with? Thanks again for the posts man!! |
08-30-2009, 02:28 PM | #52 | |
Rep 10,587
the bottom end of the motor is all stock w 85k miles on it. Thicker MLS headgasket and ARP studs have dropped the compression ratio though. stock engine has been good for most people until 650whp or so. I dont plan on getting to that point but when its necessary i'll build the motor. car came with a Technique Tuning stage II setup, great kit.
08-30-2009, 07:37 PM | #53 |
Rep 10,587
UPDATE 8/30
Got a little more time....30 minutes or so and opened up the 35r to "reclock" it and rotate the compressor housing to match the old turbo. Also took the time to degrease and clean the compressor housing. Nothing crazy, more coming tomorrow night....god willing it will be mounted. Got it apart Compressor Housing (no gasket) Rotated to match the 60-1 Random parts laying around the garage, will have these organized and cleaned tomorrow too Downpipe and Wastegate pipe mid pipe and charge pipe
08-31-2009, 04:14 PM | #56 |
CHEAT TO WIN!!
101
Rep 1,347
+1.
Awesome car Sniz! keep us updated! ________ HONDA E SERIES HISTORY ________ TOYOTA SPORTS 800 ________ Vapir No2 Review ________ Headshop Last edited by OverDrive; 04-14-2011 at 09:55 PM.. |
08-31-2009, 09:15 PM | #57 |
Rep 10,587
UPDATE 8/31
UPDATE 8/31
Spent about 2 hours working on the car/turbo tonight.....work keeps getting in the way of my fun!! test fitted the gt35r to find 2 points of contact with the transmission/engine block. Problem #1 This fitting for the vacuum hose for boost control is in the wrong spot. Previous owner had the compressor housing 180 degrees in the other direction so it worked for him. Had to remove it. Will find a brass plug for this hole tomorrow and find someone to retap in a better location. Problem #2 and then the exhaust housing is/was contacting the transmission here. Spent about 30 minutes with a grinding wheel and got my clearance ITS ON BABY ok, well now its off, have to get that fitting retapped tomorrow and then it will be on for good. I have a weeping oil pan gasket and rear main seal as you can see here. These will be addressed this winter once I have more downtime on the car. thats it for today
08-31-2009, 09:33 PM | #58 |
Registered Sex Offender
573
Rep 4,759
I can't take it anymore, I need dynos! Videos!
Stop putting stuff like painted reflectors and premium package in your signature. You're embarrassing.
08-31-2009, 09:48 PM | #59 |
Rep 10,587
lol....you and me both man!!
08-31-2009, 10:13 PM | #60 |
Rep 57
Posts Drives: Evo 8, B5 S4, 335i, VW Corrado Join Date: Aug 2009
No offense, but I do not see why this project is such a big deal. If maybe you were doing a 1000+whp project then thats a little different but you aren't even going to come close to that, but it will be a pretty QUICK car.
08-31-2009, 10:16 PM | #61 | |
BEEP BEEP
Rep 96
I find it interesting and kinda of a big deal, considering he went from a 335i e92 to a e36.
2003 911 Turbo | K24/18G | Bone Stock Exterior |
08-31-2009, 10:24 PM | #62 | ||
Rep 10,587
at least i dont think so
08-31-2009, 10:34 PM | #63 |
Rep 57
I guess it was the higlight on the main page of E90post.com showing this build that made me come to the conclusion that it was a major deal.
08-31-2009, 10:35 PM | #64 | |
Rep 10,587
I guess one of the admin's here like the thread so they put it up there. back to me hacking up my car....
09-01-2009, 02:50 AM | #66 | |
BEEP BEEP
Rep 96
