02-11-2021, 05:02 PM | #3 |
Ring Leader of G8X Haters
25175
Rep 8,769
Great video, and 100% agreed with Jason's points. Honestly the 0-60 and horsepower wars have become so absurd.
He also posted a great clip on his instagram showing how a Subaru Outback reacts differently to a normal launch vs being brake boosted, holding its "gears" (CVT) longer to reduce the time. Last edited by stein_325i; 02-11-2021 at 05:31 PM.. |
02-11-2021, 06:55 PM | #4 | |
Rep 4,210
David701567.00 |
02-11-2021, 11:40 PM | #6 | |
Rep 3,488
The way they were getting those 0-60 numbers was AWD clutch-drop launches. Yep, you can use the engine like a giant fly-wheel and then just slam it in and let all four wheels rocket you forward. It works...until you break the clutch and trans. It was completely deceptive. The same cars would struggle 5-60 or in passing.
David701567.00 |
02-12-2021, 04:03 AM | #7 |
Rep 4,381
FYi...the times supplied by Euro car manufacturers are all 0-60 without any roll out.
Same...Typical euro magazine tests. Sure any sensible car manufacturer is going to go to some lengths to ensure their test car is in perfect working order...but these days getting caught out in any sort of cheating would carry a high penalty so... In past times certainly a few manufacturers (ooh look at that dancing black horse in that field) were renown for having cars loaned to journalists that produced acceleration figures way faster than customer cars could match. I would have though 0-100mph is a better metric as is a laptime at the Nürburgring. https://fastestlaps.com/tracks/nordschleife The F90 M5C at #88 has some good company. |
02-12-2021, 08:50 AM | #8 | |
Rep 2,956
pz6193281.50 |
02-12-2021, 11:38 AM | #9 |
Rep 3,488
Even 1/4 isn’t all that telling, small diameter turbos that spook fast plus awd can have deceivingly decent 1/4 times, but are totally out of breath at the end. The trap speed at the end really tells that story better. This is where you start seeing the effects of drivetrain drag start to compound for the awd that doesn’t have the power to back it up.
02-12-2021, 12:44 PM | #10 | |
Rep 3,257
Side note: Great to see Jason back on Youtube |
02-12-2021, 06:09 PM | #13 |
Rep 1,696
Posts Drives: 2022 X3 M40i, 1983 911SC Join Date: Jan 2021
2.6 Sec in Launch Control.
50 back to back L.C. in a row to celebrate the 911 50th anniversary. https://www.carthrottle.com/post/the...hard-launches/ |
02-13-2021, 06:20 AM | #15 |
Rep 99
What about cars that are quicker 0-60 than the manufacturers claims? Is that also cheating? Or modesty?
I think a true reflection of power is 1km times and exit speed. And 100-200kph times. |
02-13-2021, 02:07 PM | #17 | |
Rep 4,145
Posts Drives: '18 M2 6MT Join Date: Sep 2019
02-13-2021, 11:31 PM | #18 | |
Rep 3,488
Fun cars, short gearing and turbo meant you could work the gears at lower speeds, but those are some of the best examples of what I was talking about. I had a WRX. I know how high those RPMs buzzed on the highway. If you kept it, you would have had to take the block out and rebuild it at some point, due to the nature and design of it.
02-14-2021, 08:43 AM | #19 | |
Rep 4,145
Drivetrain loss is significant in an AWD car, and mine was no different, but in my normal mod-spirit (OEM+), my car ran very well with just an exhaust and professional tune. The car ran 7.9 in the 8th (I don't have a local ¼) with countless 1.6 60-ft times in the 36,000 miles I had it, and I never had any issues other than a turbo oil-feed line crack, which was created by the down-pipe hanger cracking, causing excess movement. A quick fix anyway.
And BTW, my 0-60 was good enough to best almost any car at the track, and on the street...even with the impossibly short 1st gear. Quote:
Careful with your Subaru racism, NASIOC has colored your judgement, and not in the best of ways. |
02-14-2021, 12:19 PM | #20 |
Rep 3,488
Yeah, I know that many that make it to 100k and past. That doesn’t change the reality of the engine design. Your times, especially because we are taking short distances, are the result of turbo+awd, it’s exactly the situation being described here, where the car isn’t going to have nearly as much top end and passing power.
These cars can do 5k clutch drops described above (although with what frequency is the question) to nail good “0-60” times. Rolling 5-60 and passing numbers are more indicative of its performance at speed. Last edited by RM7; 02-14-2021 at 10:59 PM.. |
02-14-2021, 12:45 PM | #22 |
25175
Rep 8,769
