07-31-2023, 01:55 AM | #1 |
Rep 66
Upgraded K+DCAN Cable - Interests ?
Hello E39 Community,
i upgraded my K+DCAN Cable with the enhanced Firmware and I want to ask you, if there is any interest in buying an upgraded K+DCAN Cable. Advantages over normal K+DCAN Cable: - DME Flash of M3/M5/M6 without ECU corruption - SMG Flash of M5/M6 without ECU corruption - Gearbox TCU Flash of E9X without ECU corruption - coding TRSVC Module in E9X when retrofitted in E9X - read FSC directly with SWID Reader and K+DCAN (no ICOM needed) - faster CAN Communication - safe ECU flashes due to software fuses Edit 1: (07/31/2023) - MHD Flashes under 1 minute - XHP Flashes with OTG much faster So in general: much safer, faster and 100% reliable Cable than the normal K+DCAN cables. This upgraded K+DCAN Cable can be easily updated with USB, no Soldering or Pins required. The K+DCAN Cable will come with the latest FTDI Drivers. It is still working for BMW/MINI Cars from 2000 until 2012. The switch position controls the connection before 03/2007 and after 03/2007. If there is any interest, i would try to make a good offer ! You can PM me if so. Thank you ! |
